Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
where is the factory amp located???
Old Jul 21, 2008 | 12:13 PM
patrick4588's Avatar
Default where is the factory amp located???
2006 civic with the nav unit. where is the factory amp?
Old Jul 21, 2008 | 12:46 PM
Default Re: where is the factory amp located??? (patrick4588)
found the amp, its under the center console below the dash. now looking at it, i want to cut the front speaker outputs to connect them to a 4 channel amp in the trunk. this way i dont have to run new speakers through the doors. does anyone know which wires coming out of the plug is the outputs? i know the speaker wire colors, but there are 2 of a lot of them.
Old Jul 21, 2008 | 03:15 PM
draken187's Avatar
Radio 12v white + radio harness
Radio Ground black - radio harness
Radio Ignition purple + radio harness
Radio Illumination gray or red/black + radio harness
Factory Amp Turn-on lt. blue + radio harness
Power Antenna gray + radio harness
LF Speaker +/- lt. green - pink +,- radio harness or amp under ctr dash
Notes: On vehicles with the amplifier, the LF tweeter wires are red (+) - green (-).
RF Speaker +/- gray - brown +,- radio harness or amp under ctr dash
Notes: On vehicles with the amplifier, the RF tweeter wires are pink (+) - blue (-).
LR Speaker +/- yellow - brown +,- radio harness or amp under ctr dash
RR Speaker +/- blue - orange +,- radio harness or amp under ctr dash
Notes: On vehicles with the amplifier, the subwoofer wires are green (+) - red (-).
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: 555U
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes: Standard on all models
Old Jul 21, 2008 | 03:16 PM
draken187's Avatar
Default Re: where is the factory amp located??? (draken187)
that list also verifies that it is the amp under the dash
stugatzo
Audio / Security / Video
Dec 7, 2022 07:07 AM
noob with an RS
Dec 29, 2004 09:41 AM
Asahi
Jun 6, 2002 12:37 AM
JimmieD
Jul 6, 2001 02:41 PM
