welding SS to MS
Old Jul 21, 2008 | 09:27 AM
See Are X's Avatar
Default welding SS to MS
I'm trying to weld a mild steel rod(for the muffler hanger) I picked up at Home Depot to a stainless steel muffler. I'm using a Lincoln gasless mig welder I borrowed and it did not work. Do I need a SS rod? Or SS wire for the welder?
Old Jul 21, 2008 | 09:43 AM
garados's Avatar
Default Re: welding SS to MS (See Are X)
I had no problem welding mild steel to stainless with my flux-core welder. I used stainless steel flux core wire.
Old Jul 21, 2008 | 10:09 AM
Agtronic's Avatar
Are you sure the rod is steel?
You should have no problems welding that rod to the muffler, unless you don't have enough power (which is likely).
uberEFtuner
Welding / Fabrication
Sep 6, 2011 09:05 AM
Ron454321
Sep 26, 2007 09:29 AM
huge230
Apr 4, 2006 10:16 AM
E-lude78
Jul 8, 2003 10:34 AM
