90-91 sedan dash in a 88-89?
Old Jul 21, 2008 | 01:06 AM
sasinorm01's Avatar
Default 90-91 sedan dash in a 88-89?
just wanted to know if it fits in cause my dash is cracking and the junk yard has a ton on 90 91s out there
Old Jul 21, 2008 | 07:57 AM
rbwdriven's Avatar
yes it will work but use the wiring harness from your 88-89. the cluster will need to be rewired. I did mine takes a little bit but it is not hard. Also remember that your hazard is on your column and the 90-91 is on the cluster cover.
There is wiring that is need to be swapped but it is not a hard thing to do. Have a manual it is pretty easy from there.
make sure you get all the parts for the 90-91 since the fuse cover is different. Get the complete dash if possible.
gnxpro24
30
Sep 16, 2010 05:13 PM
4g4dcruisin
14
Apr 28, 2010 06:17 AM
BSeriesRescueteam
May 7, 2009 10:29 AM
julioboostamante
Dec 7, 2007 04:57 PM
dem0nk1d
Jul 12, 2007 05:49 AM
