d16z6 or d16y8??
Old Jul 20, 2008 | 05:20 PM
sorullo's Avatar
Default d16z6 or d16y8??
i was on the track yesterday..and i saw two civics.. one with a d16z6 with edelbrock supercharger. and the other civic with a stock d16y8 engine.. no mods on it.. but the y8 was faster than the z6 supercharger.. and i really got surprise!!
so what do you guys think.. cuz i'm biulting my 89 crx for the track but still does not decide which of both engines to choose..
really need an expert advice...
Now this is the track that i'm going to race.where nascar races. in california speedway but i'm in stock category.
Modified by sorullo at 8:01 PM 7/20/2008
Old Jul 20, 2008 | 05:43 PM
sorullo's Avatar
Default Re: d16z6 or d16y8?? (sorullo)
by the way ,, is the time attack race that i'm into in...the only mod they will allow me to run is a supercharger or turbo...no nitrous, but the engine decision is killing me really. and also have to run with the same series engine.. any D series...
Old Jul 20, 2008 | 05:46 PM
donotswitchoff00's Avatar
the motor prob was worked internally or maybe nosing it
Old Jul 20, 2008 | 05:47 PM
redef90si's Avatar
I beleive from the factory the Z6 motor is stronger all around Another thing you should consider is what tranny you will be wanting?si has short gear ratios(better when exiting turns etc) or a dx tranny with the longer gear ratios(better for the straightaways) good luck
Old Jul 20, 2008 | 05:59 PM
sorullo's Avatar
Default Re: d16z6 or d16y8?? (redef90si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redef90si &raquo;</TD></TR><TR><TD CLASS="quote">I beleive from the factory the Z6 motor is stronger all around Another thing you should consider is what tranny you will be wanting?si has short gear ratios(better when exiting turns etc) or a dx tranny with the longer gear ratios(better for the straightaways) good luck </TD></TR></TABLE>
so then what u are saying is that i should get a d16z6 and rebuilt it internally, make the head a litlle bit bigger and put some racing internals and boost it with a supercharger,, ok that. i understand.. but don't know about the tranny. cuz the guy of the d16z6 had a s20 tranny and i didn' t have the change to look under the tranny of the y8 guy.. which i saw he was really fast!!!
Old Jul 20, 2008 | 06:03 PM
sorullo's Avatar
can i just mix ratios inside the tranny..like.. 1,23, make it SI ratios like the S20 .. and then put 4, 5 with the dx ratios.. is that possible??
Old Jul 20, 2008 | 06:05 PM
redef90si's Avatar
yup but unless you know a "experienced"honda tranny guy they(tranny shop)will rape you for labour.
Old Jul 20, 2008 | 06:07 PM
sorullo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redef90si &raquo;</TD></TR><TR><TD CLASS="quote">yup but unless you know a "experienced"honda tranny guy they(tranny shop)will rape you for labour.
ohh i do not worry aboput that.. i got firends that can do the job just for $ 100 bucks.. but i just want to know if is that possible..!!
Old Jul 20, 2008 | 06:09 PM
sorullo's Avatar
and also how about the GSR ratios can this ratios be possible to swap into the si tranny and will go better is this possible?
Modified by sorullo at 8:27 PM 7/20/2008
Old Jul 20, 2008 | 06:17 PM
redef90si's Avatar
gsr is a close ratio tranny aswell, personally i would go with the si tranny and swap out the 5th gear ratio of the si with the dx..... goodluck man keep up posted
Old Jul 20, 2008 | 06:56 PM
sorullo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redef90si &raquo;</TD></TR><TR><TD CLASS="quote">gsr is a close ratio tranny aswell, personally i would go with the si tranny and swap out the 5th gear ratio of the si with the dx..... goodluck man keep up posted</TD></TR></TABLE>
i'll do that... thanks.. but the way i'll put some pictures of the track here on california sppedway where nascar races are done. i'm plannig to race... just look on my first post up on top. i'll edited so you have and idea of the track
Old Jul 20, 2008 | 07:00 PM
redef90si's Avatar
thanks man what do you have in mind as far as brake setups and suspension?
Old Jul 20, 2008 | 07:05 PM
redef90si's Avatar
That looks beautiful wow
sorullo's Avatar
well i'm thinking on goin tein.. which everybody on the track have it.... but any suggestions welcome..
Old Jul 20, 2008 | 07:11 PM
sorullo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redef90si &raquo;</TD></TR><TR><TD CLASS="quote">That looks beautiful wow </TD></TR></TABLE>
yeah i know subscription is only $ 600 for two days .. one day your training day and that includes your lap record computer data.. various races during the day!!
and if you qualify as one of the best time you get to the time attack challenge on the second day..
Old Jul 20, 2008 | 07:12 PM
fortymcpants's Avatar
With a D series motor you will not be able to run a GSR transmission or a 99-00 Si
Old Jul 20, 2008 | 07:15 PM
sorullo's Avatar
Default Re: (fortymcpants)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fortymcpants &raquo;</TD></TR><TR><TD CLASS="quote">With a D series motor you will not be able to run a GSR transmission or a 99-00 Si</TD></TR></TABLE>
i know that.... but how about swaping the internals gears like 5 th gear?? will it help me to get a good speed on the long run..
Old Jul 20, 2008 | 07:16 PM
redef90si's Avatar
forty is right, you can run the y8 tranny from an ek though,just no b series stuff
Old Jul 20, 2008 | 07:21 PM
sorullo's Avatar
Default Re: (redef90si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redef90si &raquo;</TD></TR><TR><TD CLASS="quote">forty is right, you can run the y8 tranny from an ek though,just no b series stuff </TD></TR></TABLE>
ok got it. so my only choice is the 5th gear of the dx civic..'' i'l try that
but if you have any other suggestion!! just hit me back i will need a lot of help..!!!
Old Jul 20, 2008 | 07:25 PM
You have the Si/Ex from the 92-95 (D16Z6) to choose from also. I would stay away from the CX and VX. If you really want some help with setting up the perfect transmisison PM Bense, he is the king D trans, and probably more.
Old Jul 20, 2008 | 07:27 PM
redef90si's Avatar
Default Re: (sorullo)
you can run any d series trannys but a ef si tranny will be cheap and do the trick,As i said i'd swap out the 5 gear rato and swap in the dx.Best of luck man if you need anything for a Z6 i have pretty much anything.Email me at Mattias.86@hotmail.com if you have more questions,Matt
Old Jul 20, 2008 | 07:31 PM
sorullo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fortymcpants &raquo;</TD></TR><TR><TD CLASS="quote">You have the Si/Ex from the 92-95 (D16Z6) to choose from also. I would stay away from the CX and VX. If you really want some help with setting up the perfect transmisison PM Bense, he is the king D trans, and probably more.</TD></TR></TABLE>
Who is Bense and how can i have a hold of him?
Old Jul 20, 2008 | 07:40 PM
jdmeg6118's Avatar
lol
Old Jul 20, 2008 | 11:29 PM
Syndacate's Avatar
Default Re: (jdmeg6118)
Z6 &gt; Y8
Always.
Either the Y8 had something hidden that you weren't seeing (like heavy weight red), it had an excellent driver, the Z6 driver was very poor, or the Z6 wasn't running right.
Pick your poison as far as those 2 go, but go with the Z6.
Old Jul 21, 2008 | 04:28 AM
iamthefollower's Avatar
Default Re: (Syndacate)
an si transmission isn't that low geared, I know on an 88-91 si tranny they can go around 140mph to 150mph so you wouldn't have to swap the 5th gear out, they do give a better take off then the dx tranny though. The Dx tranny will have higher gear ratios through all gears, but if you wanna go with an eg tranny or an ek tranny you'll have to do the cable to hydro conversion on it, because you did say it was an 89 crx right. You can't take the B series internals and put in a d series tranny. Now for the motor the z6 would be a better motor, and you could put the y8 intake on it and give it a little more torque right off a bat, but then build the d-series and it would be a good running car with the si tranny on it.
