96 civic stock sohc prob
aight so here is the prob. that i am having first i my check engine light is on when i hook up my modis (snap-on) diag scanner it shows no comm. to pcm so i checked all the fuses and there where a feww that where blow so i replace them and still no comm. than i call hotline and they tell me to holds the reset button on the side of the pcm and the the check engine light should flash multiple times. but did that no flashing. and still no comm. to pcm that is a prob. because i have to get and inspection and you cant with the light on ok.
prob. 2
while driveing in any gear and mid range rpm the car looses all engine power like a really bad bogg than i let my foot off the gas and go full throttle and the car pulls like its built but the prob. is only intermitten i have done a complete tune up plugs wires filters oil change but the prob is still there. and it has an erratic idle some times again intermitten please ht help me out
prob. 2
Make sure you know how to use that scanner properly, also check to make sure the OBD 2 port is in good condition and that the "K line" wire is properly connected. What reset button are you talking about.
use this if you want to see the CEL blink:
https://honda-tech.com/zerothread/1901557
big_poppa492004
10
Apr 28, 2009 05:32 PM
meaux
Feb 9, 2009 01:12 PM
