Cable speedo install issue
Ok, so im finishing up my b16 swap and i have to install the speedo cable. I have the speed sensor installed there but the cable going INTO it is what I have a question about. The end of the cable is slotted, and it fits one way into the speedo. then about a half inch up there is a silver slotted piece that im guessing needs to be fastened or something?
I am really confused on how that cable goes in and if I am missing a part. Any info would be awesome. Thanks.
Here is kinda how the situation is (all the parts on the right side, from part 9 down)
I tihnk I have everything, am I just missing that pin that goes around it in that slot to hold it im guessing?
This is the clip that fastens the cable to the speedo housing
are you missing this? Im not sure about what your not sure about?
-how cable is inserted
-how to fasten clip to cable
OK, sorry if i was a little vague.
I have the cable from the cluster, and at the end it has a metal piece with a notch (that goes into the VSS with the notch as i can see). On top of that cable, there is a thicker metal piece that fits almost perfectly snug in the hole on top of the hole that the cable went into. I dont see anywhere that that clip should go. That piece on top of the notched piece at the end of the cable has a slotted spot where a clip should go, but that part of the cable goes INTO the speedo hole and is hidden, unless i am doing this completely backwards or something.
Sorry. I'll take pics tomorrow if I didnt explain myself well enough.
This thread helped me when I was having trouble with my speedo after a swap.
https://honda-tech.com/zero...44581
Briank24
Jan 16, 2012 07:12 PM
