HELP! Need details on code 15 (ignition output signal)
Hey, guys. I've been having problems with my car dying as I drive, then starting again after awhile of sitting and frequent cranks. I've had this problem before; however, I used an ohmmeter and a voltage check that time and it ended up being my ignition coil. This time around, I figured it may be the same problem, so I replaced the coil. During the first test drive, it failed on me again. At this point, I'm convinced it must be the ignitor (ICM). However, the main relay could also be at fault (which I'm not familiar with). If anyone has any tips or advice on how to narrow this problem down, I'd appreciate it!
slammedvtec
Apr 17, 2008 02:17 PM
djnikko
Mar 1, 2004 09:12 AM
djnikko
Mar 1, 2004 06:48 AM
