IACV problem, 96 civic dx... no code w obd2 LS ecu but code 14 with obd1 LS ecu
Old Jul 20, 2008 | 08:38 AM
Cimburke23's Avatar
Default IACV problem, 96 civic dx... no code w obd2 LS ecu but code 14 with obd1 LS ecu
like the title states, i have a 96 civic dx that has a b20 swap in ti with obd2 LS intake manifold, obd1 tb with fitv, iacv has been rewired correctly and i have continuity tested them. if i plug up an obd2 LS automatic ecu, it runs fine just throws a 2nd o2 code. once i plug up the obd2a-obd1 conversion harness and 5spd obd1 ecu, it throws a code 14. any ideas what would cause this? ive swapped iacv's already and no help. thanks in advance
Old Jul 20, 2008 | 05:13 PM
Cimburke23's Avatar
Default Re: IACV problem, 96 civic dx... no code w obd2 LS ecu but code 14 with obd1 LS ecu (Cimburke23)
well, swapped IACV's when engine was warm and light went off, started it about 3 hours later and it came back on... i need help!!
slo_hatch
Sep 3, 2009 01:30 PM
slo97coupe
Apr 6, 2006 07:46 AM
AzNpRiD3
May 14, 2004 06:05 PM
EGhybridHB
Jan 20, 2004 11:47 AM
