My Transmission keeps slipping
Old Jul 19, 2008 | 11:36 PM
doubleecho's Avatar
Default My Transmission keeps slipping
When I first pull off 1st and 2nd gear seem to sort of over-rev then shift into gear. But once the engine warms up it's fine. Anyone know what's going on? I checked the fluid level and it's good. Any help would be much appreciated.
Old Jul 20, 2008 | 07:19 AM
TheMuffinMan's Avatar
He knows where you live!
I'm sure you know that those automatic tranny's are notorious for crapping out right?
Old Jul 20, 2008 | 02:58 PM
ronqqq's Avatar
Default Re: (TheMuffinMan)
try some "trans X"
Old Jul 20, 2008 | 04:10 PM
YeuEmMaiMai's Avatar
Default Re: My Transmission keeps slipping (doubleecho)
time for a rebuild........I would personally recommend getting a reman from honda than going to a local shop. I had my trans rebuilt in my 98 accord V6 by kennedy transmission and the unit failed no less than 4 times within 11K miles.........I should have bought it at the honda dealer and installed it.
Old Jul 23, 2008 | 11:28 AM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
Default Re: My Transmission keeps slipping (YeuEmMaiMai)
How do you get a remanned from Honda? Cost?
Also, how easy are these to install? Just drop it out and put in new? Cross member in the way? Need to lift engine at all?
Old Nov 13, 2008 | 05:07 AM
Default Re: My Transmission keeps slipping (phoenix_iii)
As winter approaches, this is happening more...
Options? My previous questions one post above still apply!
Old Nov 13, 2008 | 05:24 AM
Mr Yamada's Avatar
You'll need to suspend the engine, then drop out the subframe, then you can remove the trans.
Old Nov 13, 2008 | 05:47 AM
Default Re: My Transmission keeps slipping (Mr Yamada)
Does this require a cherry picker, or can you do the jack+wood under the engine...
ugh... subframe != cross member, subframes are a bit of work if I recall correctly.
Costs are used trans + 300-400 to change them out?
PsXtreme
May 13, 2017 06:04 PM
jmh51193
Jan 17, 2015 10:40 PM
clayton1
Transmission & Drivetrain
Nov 21, 2013 11:55 PM
Cashpoboy
Apr 17, 2008 05:07 PM
mrmanuke
Mar 2, 2007 01:37 PM
