what's the diff between the p05 and p06 ecus???
Old Jul 19, 2008 | 04:58 PM
ten2doyle102's Avatar
Default what's the diff between the p05 and p06 ecus???
I just noticed that my civic is running on a p05 ecu. it had an at / mt swap on it. Just curiuos!
Old Jul 19, 2008 | 05:10 PM
94EG8's Avatar
Seagull Management
Default Re: what's the diff between the p05 and p06 ecus??? (ten2doyle102)
P05 is a for a D15B8 found in US CXs. P06 is for a D15B7 found in US DX, LX and canadian CX,DX,LX,EX civics
Old Jul 19, 2008 | 06:26 PM
d357r0y's Avatar
I think the main difference is 1 wire and 4 wire 02 sensors.
Old Jul 20, 2008 | 08:00 AM
do you have any idea hy a p05 would be in my civic lx sedan with the d15b7??? also, i have had it running my d16z6 until i get my p28 in the mail, is that going to be a problem????
Old Jul 20, 2008 | 08:14 AM
Syndacate's Avatar
Default Re: what's the diff between the p05 and p06 ecus??? (d357r0y)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d357r0y &raquo;</TD></TR><TR><TD CLASS="quote">I think the main difference is 1 wire and 4 wire 02 sensors.</TD></TR></TABLE>
That's "a" difference, the main difference is the fuel maps, the CX is a lot more fuel efficient than the B7.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ten2doyle102 &raquo;</TD></TR><TR><TD CLASS="quote">do you have any idea hy a p05 would be in my civic lx sedan with the d15b7??? also, i have had it running my d16z6 until i get my p28 in the mail, is that going to be a problem????</TD></TR></TABLE>
'Cause somebody put the wrong ECU into it - common with hondas, people always seem to go under the "eh, it'll work" notion. It shouldn't be a problem as long as you keep the revs down - if they go up the CX's fuel tables are lower, you can lean out and sling a rod using a CX ECU in a B7.
Just keep the revs down and you'll be fine.
Old Jul 20, 2008 | 08:33 AM
oh.....i'll do that from now on.....oops!
my p28 should be could next week sometime too, so it should be good then
slo_hatch
Feb 7, 2008 08:56 AM
JDM_Frijoles
May 18, 2006 10:17 PM
2SlowDC
Audio / Security / Video
Apr 15, 2006 08:55 AM
DISROK1
Nov 27, 2005 04:26 AM
chad
15
Dec 22, 2004 06:00 PM
