Code 15 ignition output signal
Long story short i bypassed my main relay for the fuel pump, for a kill switch.
Car runs fine, been fine for awhile now, just keep getting this code.
Now i understand the reason i'm getting this(because the the ignition is not sending a 'run' message to the fuel pump)
Now my question is since this is throwing the code will it retard my timing? i doubt it should but never know.
Anybody?
Anybody?
If you hacked your distributor harness for a swap, check the blk/yel wire if you spliced it anywhere, its probably corroded.
If he had a bad coil or ICM, it wouldn't run.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k »</TD></TR><TR><TD CLASS="quote">If you hacked your distributor harness for a swap, check the blk/yel wire if you spliced it anywhere, its probably corroded.
If he had a bad coil or ICM, it wouldn't run.</TD></TR></TABLE>
yes it will run. ive personally had a car that had a slight hickup then would throw the code. but the car still ran. but only would hickup here or there
Dizzy is brand new, and i know my problem is in the main relay, ingition output signal sends a signal to the mainrelay telling it to turn on the fuel pump, but like i said i know this. all i want to know is will my car go into limp mode just because of the code15?
I never plan on wiring back up the fuelpump to the mainrelay again, so i guess i'm gonna always get this code?
this has nothing to do with finding out why i'm getting code 15.
Please read first post
TrippyZippy
Oct 9, 2007 12:52 PM
