98 Predlude - JDM Swap wont start
Old Jul 19, 2008 | 01:56 PM
cikota's Avatar
Default 98 Predlude - JDM Swap wont start
I have just installed a JDM H22A in my 98 base model prelude. I checked all the wiring 3 times, I dont see anything wrong. Car turns, starts briefly and then immediatly shuts off.
I did swap my intake from my old engine and purchased a brand new oil pump to put on the crank sensor.
One thing I noticed is my clutch pedel has no tension, it falls directly to the floor, I have to lift it by hand. I did not bleed the slave cylinder yet.
Can anyone point me to the right direction. Im sure some of you have done this swap.
thanks
Old Jul 19, 2008 | 01:58 PM
98vtec's Avatar
moderator emeritus
Default Re: 98 Predlude - JDM Swap wont start (cikota)
https://honda-tech.com/zerothread/2084037
have you read that?
Old Jul 19, 2008 | 02:31 PM
cikota's Avatar
i am now, i did not swap my balencer shaft pulley, exhaust manifold, themostat.
exhaust bolted right on
ill keep reading
Old Jul 21, 2008 | 08:54 PM
cikota's Avatar
i got it started, by unpluging the sensors and plugging them back in
It runs pretty rough, if I gas it to 3000rpm it wants to stall, still ooking into it
also, I still cant bleed the clutch slave
Old Jul 22, 2008 | 02:56 PM
Acidcrakker's Avatar
Default Re: (cikota)
Your timing sounds off. And you are going to have to bleed that clutch. Compared to swapping an engine, its as simple as Windexing your windows.
Accord_Addict
Nov 17, 2016 08:38 PM
da_coolest
Jul 17, 2009 03:57 PM
1990hondaHF
Mar 2, 2004 10:48 PM
