what 1/4 times do you think my R will put out?
Old Jul 20, 2002 | 04:51 PM
hooptie157's Avatar
Default what 1/4 times do you think my R will put out?
Alright here's the mods I have (or will have, if I don't sell the car)
01 py ITR (the yellow is good for .2 seconds)
ATS final drive
Exedy Clutch
Toda flywheel
Stock rims w/ 205/50/15 azenis
Mugen Header 4-1
Mugen twin loop exhaust
Carsound Cat
Spoon drop in filter
ok what do you think with just those mods??
Now add these mods to those and what time to you think?
JUN 3 cams
JUN ECU p28 chipped
JUN valve train
AEM adjustable cams sprokets (w/ loctite and upgraded bolts, I know I know)
and tuned
what do ya guys think, be honest here, thanks
Old Jul 20, 2002 | 05:02 PM
uNF$@#!'s Avatar
Default Re: what 1/4 times do you think my R will put out? (hooptie157)
16.0 sec
Old Jul 20, 2002 | 05:06 PM
TypeR1558's Avatar
New User
I think you would gain a lot by getting a new exhaust. The design of the Mugen is restrictive, and those JUN III's are gonna wanna breathe more.
first setup .. i would say mid-13's= possible
second.. i would say low-13's on slicks with some weight reduct., MAYBE high 12's with weight reduction/slicks/different piping/raise compression(esp. testpipe) -tuning!
Others jump in..
Jon
514_type R's Avatar
Default Re: what 1/4 times do you think my R will put out? (Soup ****)
id say high to mid 12 with good traction, assuming that your a good driver and your have the jun 3 head package etc....
a R with I/H/E, advance timing make high 13 easy with a good driver, ive seen a guy in mtl do 13.9 only with a alternator pulley and toyo ra-1 tires
ITR.00-1282
Guest
Posts: n/a
1. somewhere in the low 14s
2. 13s definitely
Old Jul 20, 2002 | 05:13 PM
01PYITR's Avatar
with out a doubt, slower then me.
But should be in the mid 13s but don't see much fater then that without tires.
I know you want to hear low 12s but I don't think so. not yet
Old Jul 20, 2002 | 05:15 PM
hooptie157's Avatar
Default Re: what 1/4 times do you think my R will put out? (01PYITR)
which setup are we talking about here rob? What I've got now or want I MIGHT get installed (ehh get hush hush)
Old Jul 20, 2002 | 05:18 PM
01PYITR's Avatar
what ya have now might get you into the very low 14s and for the new stuff with the old stuff maybe mid 13s
Old Jul 20, 2002 | 06:48 PM
514_type R's Avatar
with your present, if your a good driver you can hit mid to high 13, with good tires
Old Jul 20, 2002 | 07:00 PM
ITR21's Avatar
Default Re: what 1/4 times do you think my R will put out? (joeyb18c5)
13's all day
Old Jul 20, 2002 | 07:02 PM
hybrider's Avatar
as present, high 13's after a couple runs
Old Jul 21, 2002 | 11:19 AM
hooptie157's Avatar
Default Re: what 1/4 times do you think my R will put out? (hybrider93)
what about after the mods
Old Jul 21, 2002 | 11:41 AM
acurism's Avatar
New User
Id say 13.7- 13.9 before and 13.2-13.5 after assuming thats on slicks
Id also look into hondata
[Modified by acurism, 8:43 PM 7/21/2002]
[Modified by acurism, 8:44 PM 7/21/2002]
WayneGro
Nov 7, 2003 05:18 PM
hooptie157
Apr 16, 2003 06:35 PM
arren123
Jan 1, 2003 09:45 AM
UnhuZ
Oct 12, 2002 08:06 AM
hooptie157
Jun 3, 2002 08:58 PM
