Stock gsr 11.905@118.06
Old Jul 19, 2008 | 12:53 AM
gringotegra's Avatar
Default Stock gsr 11.905@118.06
Well its about time i got into the 11's!!!!
Stock gsr turbo just crossed over 160k miles
AFI street kit 57 trim 12psi E85...
60ft : 1.754
1/8th : 7.726
mph : 93.75
1/4 : 11.905
mph : 118.06
The slicks are 25x8.7x13
I still think that the slicks are too tall for my power level. The car has been 12.57@120 on street tires...i think it could go 122 on street tires if i could take it further in 4th gear...i hit the rev limiter about 30ft before the end of the 1/4 on street tires...
Over all id say for the slicks being over 2 years old and being able to cut a 1.754 60ft with an opendiff is a good thing....
I believe that the car can do better...im thinking i can get it to 11.7 if i can get some smaller slicks these 25's are too big but they seemed to work tonight!!
Old Jul 19, 2008 | 08:03 AM
96 GSR-T's Avatar
Nice work, are you still on OEM axles?
Old Jul 19, 2008 | 08:18 AM
Turbocivic94's Avatar
Default Re: Stock gsr 11.905@118.06 (gringotegra)
congrats
Old Jul 19, 2008 | 08:43 AM
SpoolnG2's Avatar
Default Re: Stock gsr 11.905@118.06 (Turbocivic94)
What power did you make on the dyno with the 12psi?
Old Jul 19, 2008 | 09:47 AM
Default Re: (96 GSR-T)
Thanks guys!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">Nice work, are you still on OEM axles?</TD></TR></TABLE>
Yes sit OEM axles FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 &raquo;</TD></TR><TR><TD CLASS="quote">What power did you make on the dyno with the 12psi?</TD></TR></TABLE>
havent been on the dyno since i retunned on 12psi...but i am guessing it has between 350-360whp....2700lb car trapped 120mph.
The car made 321whp on 10lbs on pump gas..
Old Jul 19, 2008 | 10:47 AM
a1320addict's Avatar
Default Re: (gringotegra)
I told you it'd happen, congrats Myles. Definitely put a set of 23's on .
Old Jul 19, 2008 | 10:49 AM
95dxsir2's Avatar
good job
heres a good site to check tire size/final drive/speed chart
http://www.fatboyraceworks.com/gears/
congrats on the 1.7 with an open dif.
now get a lsd
Old Jul 19, 2008 | 11:36 AM
Default Re: (a1320addict)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320addict &raquo;</TD></TR><TR><TD CLASS="quote">I told you it'd happen, congrats Myles. Definitely put a set of 23's on .
thanks joel!!! yeah i need to try some 23's...the only thing is i think i will run out of gear...considering my street tires are 205/50/15's = 23.07 inch tires and i hit the rev limiter 30ft before the end...so as the car sits i cant trap any higher unless i take the rev limiter up...and i dont quite want to do that yet.... so i think with the 23 inch slicks i might do the same... but there is only one way to find out!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dxsir2 &raquo;</TD></TR><TR><TD CLASS="quote">good job
now get a lsd </TD></TR></TABLE>
thanks man!
haha dude that site is already saved in my Favorites on my browser
Old Jul 19, 2008 | 12:01 PM
boostedeg302's Avatar
great job! It definently has more in it. I have the same setup pretty much and went 11.82 shortshifting 3rd with a 1.69 60 with an ls tranny. I used 23 inch slicks and they worked great. Give em a try. You will be even more impressed
Old Jul 19, 2008 | 12:05 PM
Default Re: (boostedeg302)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedeg302 &raquo;</TD></TR><TR><TD CLASS="quote">great job! It definently has more in it. I have the same setup pretty much and went 11.82 shortshifting 3rd with a 1.69 60 with an ls tranny. I used 23 inch slicks and they worked great. Give em a try. You will be even more impressed</TD></TR></TABLE>
damn nice!!! yeah i need to find someone who will let me borrow their ****! hahaha
Old Jul 19, 2008 | 06:00 PM
TAP's Avatar
TAP
CONGRATS!!!!
Old Jul 20, 2008 | 09:44 AM
13173's Avatar
Default Re: (TAP)
Good job
Check out my signature. I went 11's with a stock GSR and "street tires" that are to big for my power level. I would like to crank up my boost a little more and try for lower 11's with the same tires. too bad I have not driven or touched my hatch in like 6 months and its just wasting away in the garage.
Old Jul 20, 2008 | 01:24 PM
VRD^sam's Avatar
Default Re: (13173)
Props, Congrats
95eggsr66
May 25, 2012 05:09 AM
phaphon
Apr 9, 2012 01:08 PM
gringotegra
Jun 16, 2008 08:06 PM
RaceProfessor
Dec 8, 2005 07:56 PM
ALLMOTOR18
Jul 22, 2003 10:38 PM
