Clutch problems
Old Jul 19, 2008 | 12:32 AM
02_Si_FTW's Avatar
Default Clutch problems
Hey guys. My 1st/2nd/reverse gears have been getting stuck every now and then. And sometimes it will be the opposite and even with the clutch pushed all the way in it wont go into gear. 87k miles and Im doubtful the Tranny fluid has been flushed/replaced. Anyone with previous experience on this with their ep3? Its not preventing me from driving as, If i turn the car off then restart it the gear will go in/out just as normal, Hense why i was thinking it was the fluid.. Thanks for anything guys
Old Jul 19, 2008 | 10:58 AM
WhiteOnRice's Avatar
Check clutch fluid.
Old Jul 20, 2008 | 08:01 AM
stokelessdc5's Avatar
Default Re: Clutch problems (02_Si_FTW)
Clutch. It happen in my dc5. Come home fine for the bar. Got up to go run some errands and I couldn't get it into any gear. I thought it was my cmc or my hydrolic system. I had it towed to the shop and teh mechanic said most it was my clutch sticking. Probably bad pressure plate or something having to do with the clutch. So he popped it back out. He told me if it happens again to start it in R a couple times and it should pop back out so I can drive. It hasn't happened since. But I went ahead and bought a new clutch and flywheel combo. Hope this helps.
Old Jul 21, 2008 | 01:57 AM
02_Si_FTW's Avatar
Default Re: Clutch problems (stokelessdc5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stokelessdc5 &raquo;</TD></TR><TR><TD CLASS="quote">Clutch. It happen in my dc5. Come home fine for the bar. Got up to go run some errands and I couldn't get it into any gear. I thought it was my cmc or my hydrolic system. I had it towed to the shop and teh mechanic said most it was my clutch sticking. Probably bad pressure plate or something having to do with the clutch. So he popped it back out. He told me if it happens again to start it in R a couple times and it should pop back out so I can drive. It hasn't happened since. But I went ahead and bought a new clutch and flywheel combo. Hope this helps.</TD></TR></TABLE>
Yea seems right to me.. Mine got stuck in reverse the other day. Turned it off and back on in reverse and it popped right out.. im wondering what exactly it is though
supercivicstack
Sep 12, 2009 02:24 PM
ramz7887
Oct 16, 2008 12:33 PM
kordenbrock motorsports
May 31, 2006 06:53 AM
hellrsnCL
Aug 10, 2005 08:29 AM
MiraiZ
Aug 12, 2003 06:18 PM
