tuning cams
Old Jul 18, 2008 | 08:58 PM
SOHC SPEED's Avatar
Default tuning cams
any tips on how to tune with adjustible cams, when do i retard and when to advance? thanks
Old Jul 18, 2008 | 09:08 PM
whereiscarmensandiego's Avatar
u would retard if u were running higher compression or boost and u would advance say if u ran high compression and had race fuel.. u can advance a stock motor for more hp and better mpg but there is a fine limit try little incremints and take it for a drive and watch for pinging or odd noises if u have these noises u have advanced the timing to much and need to back it off alittle.. i want to say u can prolly get somthing like 15 extra hp if u advance the timing
Old Jul 18, 2008 | 11:05 PM
mtber's Avatar
Default Re: (whereiscarmensandiego)
Cam timing adjustments should be made on a dyno so you can actually determine what settings are actually producing power...
Same applies for ignition timing adustments etc..
an2ny888
Jun 24, 2006 01:42 AM
turbociv
May 27, 2005 09:56 AM
tumbleweed
Feb 5, 2004 02:52 PM
Dr. EKology
Jul 16, 2002 12:57 AM
