Replacing master/slave cylinders in 90 accord
Could someone tell me how to replace the master/slave cylinders in a 90 honda accord, I found plenty of info on other things but not much on this. I have a Haynes manual and I can see the different pieces but it doesn't tell me exactly how to do the replacement, is it simply disconnecting hoses and "plugging" the new ones in? Are there any steps that I may overlook having this be the 1st time to do this?
If I remember correctly its pretty simple.......but you need an extra hand for sure!
Just unbolt everything Remove and Replace .........Dont forget the gaskets!
Also get a good supply of Clutch Fluid and when you start to bleed the system have someone help you.....have them open and close the bleed screw while you pump the clutch........also remember to keep the reservoir full so it wont suck air back into the system!
hmmmm if you need more help just ask........we will be here for your support if you run into a problem
Thanks so much. It's good to know there are people out there that don't mind helping out others with these situations. Have a good one.
mgerdes
Dec 18, 2007 05:38 AM
90babyblue
Apr 29, 2004 07:23 PM
