Car wont start in the mornings????
For some reason here lately when i get up to go to work in the mornings my car wont crank. ill turn the key over and it doesnt do ANYTHING. it has power all the lights and cd player comes on and ive tried jumpin it off but it doesnt do anything. and when i get back home from work itll crank right up. not makin this up either its crazy. Any suggestions
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">does the main relay have anything to do with cranking? i cant remember.</TD></TR></TABLE>
yes ain relay has the fuel pump and starter rely packaged insde it
had the same problem, beat the starter, nothing. changed the starter, nothing. it was the ignition switch. put a volt meter to the signal wire to the starter and crank it and see if you get 12v coming out. if not then the contacts inside the ignition switch went bad
xxOldschoolxx
12
Mar 23, 2013 05:38 PM
he hee.
