ZC Gearbox and D16Y7 Engine
Old Jul 18, 2008 | 06:55 AM
Zedt3's Avatar
Default ZC Gearbox and D16Y7 Engine
Will the gearbox from a ZC engine bolt up to a D16Y7 engine?
Old Jul 18, 2008 | 10:54 AM
Zedt3's Avatar
Default Re: ZC Gearbox and D16Y7 Engine (Zedt3)
anyone?
Old Jul 18, 2008 | 11:11 AM
94EG8's Avatar
Seagull Management
What ZC is it off of? if its off a SOHC Vtec ZC it should bolt up and work fine, it its off an '88 - '91 DOHC ZC it will bolt up to the block, but you'll have to convert from a hydro to cable clutch. If its off a '92 - '95 ZC it will bolt up fine and the clutch will be fine, but it takes a special intermediate shaft that bolts to the back of the engine block and i'm not sure if the D16Y7 has the holes in the block. i believe the '88 - '91 DOHC ZCs are like this as well
Old Nov 20, 2009 | 01:42 PM
mntuner2's Avatar
Yes if the d16 can accomodate the intermediate shaft from the ZC gearbox.
Dangousity
13
Jan 14, 2010 11:59 AM
stemiched
Nov 15, 2006 12:20 PM
sohcvtec91hatch
11
May 4, 2006 05:24 PM
ninjapanda
May 25, 2005 10:02 PM
