88 crx si starting problems please help
Old Jul 18, 2008 | 06:43 AM
rexfiend1877's Avatar
Default 88 crx si starting problems please help
i was just driving my car yesterday 88 crx si stock motor and all else. It was running perfectly fine and i went outside to start my car and it cranks but does not start any ideas please
Old Jul 18, 2008 | 08:42 AM
jlicrx's Avatar
Default Re: 88 crx si starting problems please help (rexfiend1877)
check the main relay and the igniter
Old Jul 29, 2008 | 02:54 PM
okmjui2000's Avatar
Try this test: Pull a spark plug and wire from the engine, take the cap off you distributer, and put the end of the spark plug wire into the coil tower. Ground the plug out on a body ground and then crank to see if you have spark in the plug you can see.
If yes, then look into the fuel system, pumps, injector, etc - try smelling the exhaust after cranking - if you smell unburned gas the fuel system is working fine.
If no spark, disconnect the computer signal wire from the igniter chip (its one of the three pins on top, and the one farthest from the single side pin). No with the plug still conected to the coil tower and grounded out where you can see it, put the key in and turn it to the run position (last one before start). Now, tap the signal wire against its matching pin - if you get spark, then the coil and igniter chip are working fine and you have a problem with the signal going to the distributor. - this could be caused by the computer, the stator sensor in the distributor, or the wires going to and from said components
Best of luck!
Crxh22ajdm
Jun 12, 2013 05:19 PM
mr_munro
Jul 25, 2012 10:43 PM
robb88crx
13
Jan 15, 2012 04:16 PM
okmjui2000
11
Aug 2, 2008 07:11 PM
CLE
11
Aug 1, 2006 08:23 PM
