Throttle cable & clutch cable question b16 crx
ok im in need of a need of a new throttle and clutch cable for my b16 crx... i read on here that they can be from a 90 integra for "better fitment". so my question is which number do i need for the throttle cable is it 9 or 10 or both??? the clutch cable is number 19 in the pic. thanks
the website lists #10 description as "throttle wire" and #9 as "actuator wire". i was thinking its #10 as well...can anyone confirm???
Are you getting new ones because you think your D-series cables won't work? IF so you're mistaken. I just did a B16A swap with hasport mounts in another hatch of mine and we used the D series throttle and clutch cables.
The only thing you have to do though is modify the throttle cable bracket to accept the throttle cable, which if you have a grinder is very simple to do.
Hope that helped you save some money. If you still need them go for it. I did too when I did my first swap.
4gencivicef9
Apr 9, 2006 07:18 PM
Origin
12
Feb 3, 2004 06:14 PM
sCeRaXn
Mar 3, 2003 05:46 PM
CRexcellence
Dec 11, 2002 03:12 AM
BoostinDC2
Feb 17, 2002 05:41 PM
