Thermostate location
Old Jul 17, 2008 | 07:44 PM
92d16z6's Avatar
Default Thermostate location
Where is the thermostat at on my d16z6?
Old Jul 17, 2008 | 07:46 PM
labtec2's Avatar
Default Re: Thermostate location (92d16z6)
under your intake manifold sorta above the starter
Old Jul 17, 2008 | 07:47 PM
slo_hatch's Avatar
follow the radiator hose that goes from your radiator to the location almost right in front of your throttle body...take that hose off and fide a SUPRISE!!! then take 3 bolts (i think) out and pull the thermostat out of the housing.
Old Jul 18, 2008 | 07:33 PM
92d16z6's Avatar
Went smooth, thanks!
2 bolts.
Old Jul 24, 2008 | 04:31 PM
92d16z6's Avatar
I noticed that the Temp gauge is not working. Any ideas on where I should look at?
I have grounded the wire and the temp gauge shot up to Hot. And the thermostat is new. I let the motor run for about 15-20 min. And it never moved.
Old Jul 24, 2008 | 04:34 PM
iluvmy2000civicex's Avatar
Default Re: (92d16z6)
You may want to bleed the system after disconnecting that radiator hose. Sometimes air bubbles can cause it to overheat. I had to bleed mine after replacing my radiator hoses on my d16y8.
Old Jul 24, 2008 | 05:17 PM
92d16z6's Avatar
Default Re: (iluvmy2000civicex)
Is it possible the sensor is bad? Or could bubbles be doing this.
After warming up i grabbed the the hose going to the thermostat, and it was hot.
Modified by 92d16z6 at 11:33 AM 7/27/2008
PolePosition08
Dec 1, 2010 07:33 PM
MJBBMANO
May 30, 2008 06:42 PM
Dc2 FrEaK
Feb 26, 2006 02:05 PM
Eckz2k
Jan 25, 2003 08:43 AM
satintegra
Jul 11, 2002 10:37 PM
