Need Help ASAP lame question
Old Jul 17, 2008 | 04:48 PM
slammed95lude's Avatar
Default Need Help ASAP lame question
so I have the JDM rain guards and i figured all but one thing out the retaining clip all the way on the end of the guard do i cut the seal and slide it through or am i missing something
Old Jul 17, 2008 | 11:35 PM
OmarR's Avatar
Default Re: Need Help ASAP lame question (slammed95lude)
I copied this off of socalprelude, hope it helps.
After this you should have everithing almost finished, now there is the 2 brackets, the 2 pins and the 2 pieces of black rubber left,
I honestly don't know how to place those brackets, all i can tnik is to put the pins in the hole at the end of the visor, and bout the rubber I have no idea, if somebody knows please help me complete this write up, I hope this helps[/quote]
I had no idea how to put those on either lol, they should come with directions. After hours of effing around, I figured there was no way to seat those brackets properly without slicing through the weather strip, I was very hesitant to do this, but once i did it and slipped the bracket through, it worked out nicely. the little pin thing, pushes through the little hole in the visor and then into the little hole in the bracket. hmm..... so anyways, make a small slice though the rubber right at the crease point and slip the bracket through, and clamp the bracket to the metal on the inside. I don't know if you all get it, pictures would most definately clear things up, butim so lazy
Old Jul 18, 2008 | 05:38 AM
95greenlude's Avatar
Default Re: Need Help ASAP lame question (OmarR)
i couldnt figure that one out either. so i just didnt install it.
Old Jul 18, 2008 | 04:55 PM
russlan44's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OmarR &raquo;</TD></TR><TR><TD CLASS="quote">I copied this off of socalprelude, hope it helps.
I had no idea how to put those on either lol, they should come with directions. After hours of effing around, I figured there was no way to seat those brackets properly without slicing through the weather strip, I was very hesitant to do this, but once i did it and slipped the bracket through, it worked out nicely. the little pin thing, pushes through the little hole in the visor and then into the little hole in the bracket. hmm..... so anyways, make a small slice though the rubber right at the crease point and slip the bracket through, and clamp the bracket to the metal on the inside. I don't know if you all get it, pictures would most definately clear things up, butim so lazy </TD></TR></TABLE>
hey were did u get the clips from, i called honda dealers by me and i had no luck.
undertheradar
Jan 7, 2006 06:45 PM
bbrian
Feb 14, 2005 02:31 PM
Nighthawk GS-R
Jun 30, 2002 03:51 AM
95CoupinIt
Apr 27, 2002 08:30 AM
