is 2 quarts of base enought for complete on a crx
Old Jul 17, 2008 | 10:45 AM
sleepencivic's Avatar
Default is 2 quarts of base enought for complete on a crx
is 2 quarts of base enought for complete on a crx jambs and engine bay? i have used 3 on my civic hatch doing the door jambs and engine bay now i have 2 left and want to spray my crx..this is base coat not single stage...i do 3 med. coats on most jobs i guess i can do 2 on the crx covers well enough....
Old Jul 17, 2008 | 12:14 PM
DDEVIANT1's Avatar
Default Re: is 2 quarts of base enought for complete on a crx (sleepencivic)
I would say no, but it depends on the colour and its transparency and coverage...
Old Jul 17, 2008 | 05:35 PM
iam7head's Avatar
Default Re: is 2 quarts of base enought for complete on a crx (DDEVIANT1)
with bay and jam? no way, esp with the cheaper stuff.
Old Jul 18, 2008 | 04:35 AM
Default Re: is 2 quarts of base enought for complete on a crx (iam7head)
its a crx they are so small and its kustom shop paint it lays down nice...i used 3 quarts exactly for my hatch with the same paint before mixing of corse
Old Jul 19, 2008 | 06:56 PM
likwidchz's Avatar
Thats quite an open ended question there,
I used napa martin senior paint and 2 quarts of base reduce 1 quart of basecoat will reduce to 2 quarts of sprayable material.
However other paints such as PPG paint cost a considerable amount of money more sometimes reduce to 1quart of basecoat will make 4 sprayable coats of material.
I would get more paint then you need so you can always fix muckups later.
check the datasheet's of the basecoat to figure out what paint mfg you will go with.
good luck
Old Jul 20, 2008 | 08:26 PM
integrapunk67's Avatar
Probably not... what base coat are you using and whats the color?
TravisB16a
Appearance Build Threads
125
Dec 15, 2010 05:25 PM
OddityDX
Jul 26, 2009 09:58 AM
DaMmniTz
10
Jun 10, 2005 01:01 AM
Nghtmar911
Mar 27, 2004 08:40 PM
