Difference between 05-06 RSX muffler and the DC5R muffler?
Old Jul 17, 2008 | 09:14 AM
redman223's Avatar
Default Difference between 05-06 RSX muffler and the DC5R muffler?
I know that the DC5R muffler has some sort of valve inside it, but I have not been able to find any information as to whether the 05-06 RSX has the same valve inside its muffler or not. If it does, then I can't see why people would pay so much for the DC5R muffler, other than the fact that its JDM...
Also, is there a difference in piping size between the 2 cars? jdmland.com says that the DC5R has larger piping than the RSX Type-S, but they are probably referring to the older RSX's and not the 05-06.
Old Jul 17, 2008 | 10:03 AM
Todd00's Avatar
I said I don't want a title!
Default Re: Difference between 05-06 RSX muffler and the DC5R muffler? (redman223)
There is no valve that opens inside the 05-06 Type S muffler. Only the DC5R gets that.
B-pipe is identical between the 05-06 USDM Type S and the JDM DC5R.
Old Jul 17, 2008 | 11:04 AM
redman223's Avatar
Default Re: Difference between 05-06 RSX muffler and the DC5R muffler? (Todd00)
Is there any way to tell the difference between the two visually? Or do they look exactly the same? I am sure that if they look visually the same there will be people selling Type-S mufflers as DC5R mufflers...
The inner diameter of the 05-06 Type-S and DC5R are both 54mm, but what about the outer diameter? Is it 60mm? I have a 60mm N1 B-pipe that I wanted to use and was just wondering if it would be a good match for an RSX muffler, I just don't know if it is 60mm inner or outer diamter? I would imagine that most aftermarket exhausts (the 60mm ones) are similar...but is that inner or outer...
Modified by redman223 at 12:15 PM 7/17/2008
Old Jul 18, 2008 | 09:39 PM
redman223's Avatar
Still need to know if there is a visual difference between the 05-06 RSX and the DC5R mufflers.
Old Jul 19, 2008 | 07:28 AM
Todd00's Avatar
Unless there are markings on the outside, physically I think they are pretty much identical.
I'm running a DC5R muffler and I couldn't tell the difference. To be honest, I seriously doubt there is much of a HP difference between the two.
blackccoupe
Nov 17, 2009 03:54 PM
lamboextreme
13
Nov 12, 2007 08:30 PM
bleezfome
Mar 8, 2007 10:36 AM
ANGELIQUE
10
Jun 2, 2006 03:18 PM
Boarderx192
Feb 7, 2006 08:09 PM
