Need help finding a 3" to 4" Aluminum reducer/cone
Old Jul 17, 2008 | 08:10 AM
Sims's Avatar
Default Need help finding a 3" to 4" Aluminum reducer/cone
Trying to find a 3" to 4" reducer/cone in aluminum. I'm not having any luck and was hoping someone on here has a reference...
Thank you.
Old Jul 17, 2008 | 10:01 AM
tony1's Avatar
Default Re: Need help finding a 3" to 4" Aluminum reducer/cone (Sims)
Burns has some.
http://burnsstainless.com/Tran....html
I have 3 to 3.5" in stock if you can make that work. I ran into a case where i needed a 3-4 and i rolled one out of .065" alum. sheet. Definitely cheaper to buy one than the time i had in building one, but if you need something quick...
Old Jul 17, 2008 | 10:15 AM
dave@passenger's Avatar
Default Re: Need help finding a 3" to 4" Aluminum reducer/cone (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Burns has some.
I have 3 to 3.5" in stock if you can make that work. I ran into a case where i needed a 3-4 and i rolled one out of .065" alum. sheet. Definitely cheaper to buy one than the time i had in building one, but if you need something quick...</TD></TR></TABLE>
I've done that before too, very time consuming. What I have since started doing for Al that needs to reduce 1" or more is pressing the tube over these 15* cones/dies I made, that will get you .5" transistion before you wreck the material, then I press the next size over the die to get the last half of the transition, I then cut and weld the two parts together and you get 1" I can do the whole procedure in under 30 minutes now, still kind of gay but its works.
Old Jul 17, 2008 | 03:40 PM
Sims's Avatar
Yeah Tony I need 3-4" I'll pick up a couple from Burns...
Thanks guys.
jeezyskillz
Dec 28, 2006 05:55 PM
jmorris
Apr 6, 2006 02:41 PM
txsynergy
May 17, 2005 08:10 PM
svmnredracr
Sep 17, 2004 08:06 AM
onyx00
Mar 1, 2004 05:50 PM
