2.5" Carsound Cat(94006)...YES/NO Answer
Old Jul 20, 2002 | 12:43 PM
CPR's Avatar
CPR
Default 2.5" Carsound Cat(94006)...YES/NO Answer
Is the 2.5" 94006 Carsound bolt-on cat (available through the likes of R&D, IPS, and SMSP) the EXACT same length as the stock Type-R cat? TIA
Old Jul 20, 2002 | 01:11 PM
Asahi's Avatar
Default Re: 2.5" Carsound Cat(94006)...YES/NO Answer (CPR)
No. THe could make it that way if you asked. But they typically make them shorter to accomodate the longer JDM style header.
Old Jul 20, 2002 | 01:12 PM
Dropspeed's Avatar
They should be, but each company is making/or has someone welding flanges on a universal cat. Should bolt right in without a problem. Call one of them if you have any concerns.
Mattj
Old Jul 20, 2002 | 01:22 PM
hooptie157's Avatar
Default Re: 2.5" Carsound Cat(94006)...YES/NO Answer (Dropspeed)
I say yes, just tell them what you got and they will weld the flanges accordingly
Old Jul 20, 2002 | 01:24 PM
Asahi's Avatar
Default Re: 2.5" Carsound Cat(94006)...YES/NO Answer (hooptie157)
the carsound "bolt on cat" is being made for JDM headers. YOu can easily order any length he needs but as he worded the question no the one they are mass making it will be too short. all they have to di is make the pipe length longer . .
Old Jul 20, 2002 | 01:55 PM
SMSP's Avatar
All the universal cats just come with 2", 2-1/4", 2-1/2" or 3" ID nipples on each end. Floating flanges are installed, flared tubing and 3 bolt flanges are welded on to a specific cat for a certain type of header and cat length. I use 94006 cats for the longer OBDI applications, 94066 for longer OBDII, 94106 for short OBDI and 94166 for short OBDII applications.
Old Jul 20, 2002 | 04:15 PM
CPR's Avatar
CPR
Default Re: 2.5" Carsound Cat(94006)...YES/NO Answer (SMSP)
Just to rephrase the question a little better...
Should the 2.5" Carsound Cat(94006) be the same length as the stock Type-R cat if I'm bolting it to a JDM style header (ie. OEM JDM 4-1, Toda, Spoon) and stock Type-R catback exhaust?
Old Jul 20, 2002 | 04:56 PM
Bob#455's Avatar
No, it won't be the same as the stock Type R cat. If you have a JDM header and stock ITR catback, you will need a "JDM-sized" cat, which is a couple inches shorter than the stock ITR cat. I say just contact one of the vendors on the board and tell them your setup...they will make sure it bolts right up.
Old Jul 20, 2002 | 05:04 PM
Tommy_Gunns's Avatar
Is the O2 bung welded on by you or is it shipped to you with the bung pre-installed?
Old Jul 20, 2002 | 05:20 PM
CPR's Avatar
CPR
Default Re: 2.5" Carsound Cat(94006)...YES/NO Answer (Tommy_Gunns)
The bung hole is there. It's as bolt-on as you can get.
Old Jul 20, 2002 | 06:19 PM
ITR21's Avatar
carsound. YES what's better....really
Old Jul 20, 2002 | 06:20 PM
Default Re: 2.5" Carsound Cat(94006)...YES/NO Answer (ITR21)
Straight pipe
Old Jul 20, 2002 | 07:09 PM
CPR's Avatar
CPR
Default Re: 2.5" Carsound Cat(94006)...YES/NO Answer (Asahi)
I was under the impression that the stock header were the same length as the JDM style headers. Can someone confirm this?
Old Jul 20, 2002 | 08:59 PM
SMSP's Avatar
On the 94166 and 94066 the bungs come already welded in the body of the cat.
CPR-
When using a JDM header and USDM exhaust, the 2-1/2" cat will need to be shorter than the stock cat by about 3/4" - 1".
Old Jul 21, 2002 | 06:50 PM
A11MotorR's Avatar
New User
Dave's Testpipe
I AM WEASEL
Mar 3, 2008 10:28 PM
KamikazeSol
May 15, 2004 02:53 AM
B_1_8_hatch
Mar 20, 2003 10:56 PM
GS-R_nut
Apr 2, 2002 05:50 AM
threatcon13
Nov 19, 2001 08:40 AM
