abs light wont turn off?
my abs light on my 00 accord ex wont turn off i check the abs pump and everything is fine. what else can it be is there a way to just pull a plug of some sort to just turn it off.
Why would you bother with that?
It's a single light.........So you'd rather have non-working ABS and have it not report it's not working?
Take it to Honda, have them do a DIAGNOSTIC and see what the problem with it is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan »</TD></TR><TR><TD CLASS="quote">Why would you bother with that?
Take it to Honda, have them do a DIAGNOSTIC and see what the problem with it is.</TD></TR></TABLE>
yeah i do plan on taking it already made a appointment for Thursday so im golden thanks bro.
it could be worn pads, low abs fluid and the abs module (looks like an ecu with orange plugs) should be in the trunk is ida bad or has been tampered with/ unplugged, look around there.
Yep, in all honesty the diagnostic is $50 in my area and it's a dealership so they'll tell you EVERYTHING that's wrong with it.
Do that then buy parts and replace things yourself
especially if it's a toughy - like the ABS system.
At some point you could just remove the system (few threads on HT how to do this) or try the $1.75 fix if applicable, or swap parts from the junkyard
especially if it's a toughy - like the ABS system.At some point you could just remove the system (few threads on HT how to do this) or try the $1.75 fix if applicable, or swap parts from the junkyard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wyotecher-4-life »</TD></TR><TR><TD CLASS="quote">hook it up to a scan tool at advance auto or the dealership or buy one and see where the problem originates lemme know what you find then. </TD></TR></TABLE>
Un Trained Idiots arise and now Wyotech made an example of you?
Scan tools from Advanced won't work on diagnosing an ABS light...wtf are you smoking?
Look it costs at least 75 at the dealer...would you rather have trained Honda technicians or some no name place touching your car?
