DPFI --> MPFI... one or two q's...
Old Jul 16, 2008 | 10:08 PM
DCRB's Avatar
Default DPFI --> MPFI... one or two q's...
ok, firstly, the search feature works pretty nice. and thank the HT gods for those first few threads at the top (the ones that say read first... lol).
so i've got plenty of know how on how to do the swap, but what i don't know is this...
i found a hella nice deal on a d16z6 intake mani w tb, and fuel rail and what not. that would work for this swap right? i'm going to be using a d15b2 (the stock motor from my 89dx). will be bolted up to a 5spd trans eventualy, gotta get it first.
being that i don't have an engine bay wiring harness, besides the auto one, i'm assuming i'll have to source both a harness from annother dx, as well as a harness for the new (to me) intake manifold?
i'm using this site:
http://www.geocities.com/teampimports/fuelinj.html
for reference, as well as this one: http://www.angelfire.com/d20/hcivic88/4gtech.html
also, if it's in the major FAQ section, just let me know, but from reading it looks like i'll need the SI harness, SI distributor, it's reccomended that i get an SI cam (going to mini me down the road instead) and an SI ecu. but for sure i CAN'T use the auto ecu right?
thanks for helpin a n00b!
Old Jul 16, 2008 | 10:15 PM
redef90si's Avatar
Default Re: DPFI --> MPFI... one or two q's... (DCRB)
you will need the parts you have listed,Do you have the fuel injectors for the z6 as well?If you need a A6 cam i have one with camsprocket,and i have z6 injectors if interested email me at Mattias.86@hotmail.com i have paypal and ship quickly
Old Jul 18, 2008 | 01:21 AM
DCRB's Avatar
Default Re: DPFI --> MPFI... one or two q's... (redef90si)
dang am i going to need a differen't thottle cable too? it looks like it? or am i just smoking crack?
Old Jul 18, 2008 | 05:38 AM
JustAnotherRex's Avatar
I've got a CRX and I MPFI'd and used the stock throttle cable. It isn't possible to adjust it compeltely right, so its kind of tricky to negotiate the go pedal, but it works.
Old Jul 18, 2008 | 09:28 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (JustAnotherRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustAnotherRex &raquo;</TD></TR><TR><TD CLASS="quote">I've got a CRX and I MPFI'd and used the stock throttle cable. It isn't possible to adjust it compeltely right, so its kind of tricky to negotiate the go pedal, but it works. </TD></TR></TABLE>
as long as full throttle works, what else do you need?
dudesmccool
Jan 7, 2016 01:19 PM
osbunjosh
Apr 1, 2012 11:55 PM
bradpee
Jun 27, 2008 04:28 AM
ilikejesus
Aug 30, 2006 06:15 PM
DualCamDan
Jul 14, 2005 06:50 AM
