91 Civic DX no spark when cranking
Old Jul 16, 2008 | 08:28 PM
carguy717's Avatar
New User
Default 91 Civic DX no spark when cranking
First of all i searched and found nothing. I have a stock 91 civic dx. I thought the fuel pump went out so i replaced it and the main relay, still not getting fuel. I did some checking and found that one of the pins on the main relay wasn't getting switched power, so I ran a jumper wire and the fuel pump came on. I tried cranking it over but it wasn't firing. I pulled a plug and set in on the valve cover and cranked it, it would only fire once the key was back in the "on" position. I replaced the ignition switch and still the same thing. I can push start the car and it runs great. Why am i not getting spark in the "start" position? btw I've checked all my fuses and grounds at least three times. Any help or suggestions would help. Thanks
Old Jul 16, 2008 | 09:17 PM
vtecb18c's Avatar
Default Re: 91 Civic DX no spark when cranking (carguy717)
maybe a bad ignition coil
Old Jul 17, 2008 | 09:00 PM
carguy717's Avatar
New User
bump
Old Jul 17, 2008 | 09:19 PM
vtec_ef8's Avatar
Default Re: (carguy717)
might be a bad ignition switch
Old Jul 18, 2008 | 06:57 AM
carguy717's Avatar
New User
Default Re: (vtec_ef8)
I've replaced that twice
mouab18c1
Feb 13, 2016 06:30 PM
jdmrexy90
15
Dec 10, 2011 08:01 PM
Arthas
Sep 2, 2010 06:42 AM
bluesking58
Aug 31, 2008 01:44 PM
rsanders21
Oct 30, 2007 10:22 PM
