Anyone running DA rear lower control arms?
Old Jul 16, 2008 | 08:01 PM
89civicdx's Avatar
Default Anyone running DA rear lower control arms?
I read some posts but still don't understand the problem
I see the the difference between the Lengths which is so little from what I see. I see both outter holes match up almost.....but what about the shock position? It's like the integra is a 1/2 inch lower? Is that the problem? Besides the - camber?
Is there some weird geometry issue I should know about? Please let me know
Thank you
Old Jul 16, 2008 | 09:01 PM
Radim's Avatar
Default Re: Anyone running DA rear lower control arms? (89civicdx)
The Blox ones fit 88-95 Civic,/Del-Sol 90-01 Integra
Old Jul 17, 2008 | 04:48 AM
89civicdx's Avatar
Default Re: Anyone running DA rear lower control arms? (Radim)
The Blox control arms are shorter though? "The extremely strong and light weight LCA's help reduce the amount of camber when lowering your vehicle's suspension."
Why would anyone run that? I wonder how much shorter? ......or maybe they are the stock length for EF and just shorter for the rest of the cars?
Old Jul 23, 2008 | 06:37 PM
efmike84's Avatar
the diffrents is the toe ajustment. you can run the da lower control arms but you need to use your toe ajustment off your civic i had that problem on me 91 hatch .
JDM JEFFREY
Nov 30, 2010 06:18 AM
northemt88
Nov 6, 2007 11:20 PM
matt1982
Mar 17, 2007 09:45 AM
SIowner
Feb 27, 2006 11:01 AM
CD7power
Jan 14, 2005 02:34 PM
