When wet sanding your car....
I decided to wet sand my miata because there were 3 key marks in it. Light, some parts pad, some parts not.
Anyways, It looks good, shines good, but if I look very carefully I can see the lines from the 2000,1500,1000 sand paper I had used while wet sanding.
Im using a meguires medium cut, and than meguires polish.
All with 10 inch orbital...
Where did I go wrong? big orbital to soft?
I would go over it with the 2000 again just to make sure the sand scratches are light then use a 3m cutting pad then the polishing. Ive always had the best results with the cutting buffing pad. Its either not sanded fine enough or its too soft of a pad
Okay... I have the fine cut cleaner pictured here (5/10 on hardness scale)
I think I will try with a hand held pad, how do I know if I am pushing to hard? Right now the pads have a little black on them (once wiping it off) Is that mean its past the clear?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GuNnErGoD »</TD></TR><TR><TD CLASS="quote">You're not using a strong enough pad or compound. I don't use meguires so I can't help you there.</TD></TR></TABLE>He's right, use 3m compounds or wizards. They are great, little expensive.
Vagitarian
Paint and Body
Jun 23, 2012 06:46 AM
matman4444
Aug 12, 2004 07:33 AM
Awar318
Jun 2, 2004 12:22 PM
