supercharging an f22b1
Old Jul 16, 2008 | 04:46 PM
MN_F22B1's Avatar
Default supercharging an f22b1
Just wondering what is an decent superchrger set -up for an f22b1 with stock internals. I heard some people have used a stillen SC from an nissan frontier but idk if that sounds legit.
anyway car is a 94 ex. auto
4-2-1 header, intake
Old Jul 16, 2008 | 05:03 PM
TheMuffinMan's Avatar
He knows where you live!
I have never seen a super charger on an F22 save for the custom one-off one a guy was custom fabbing.
Old Jul 19, 2008 | 09:03 PM
vtecb18c's Avatar
Default Re: (TheMuffinMan)
https://honda-tech.com/zerothread/1649973
Old Jul 19, 2008 | 09:04 PM
Yep
Thanks for posting that vtec that would be the one I was referring to!
Old Jul 19, 2008 | 09:05 PM
vtecb18c's Avatar
i knew what you were talking about i just had to find it
Old Jul 19, 2008 | 09:17 PM
Hawkze_2.3's Avatar
Default Re: supercharging an f22b1 (MN_F22B1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MN_F22B1 &raquo;</TD></TR><TR><TD CLASS="quote">Just wondering what is an decent superchrger set -up for an f22b1 with stock internals. I heard some people have used a stillen SC from an nissan frontier but idk if that sounds legit.
None are made, just go ahead and drop that idea.
Old Jul 20, 2008 | 10:31 AM
vtecb18c's Avatar
Default Re: supercharging an f22b1 (Hawkze_2.3)
i think he ment the xterra...just read the thread on my first post and i garantee you say [freak] it its to much work
Old Jul 20, 2008 | 03:42 PM
MN_F22B1's Avatar
Default Re: supercharging an f22b1 (vtecb18c)
well just thought i would see what there was, no real point in a turbo cause its an auto.
so what would be my best bet for power(other than an h22 swap)?
Old Jul 20, 2008 | 03:53 PM
Wagonist's Avatar
Why not the H22?
Old Jul 20, 2008 | 03:56 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MN_F22B1 &raquo;</TD></TR><TR><TD CLASS="quote">well just thought i would see what there was, no real point in a turbo cause its an auto.
so what would be my best bet for power(other than an h22 swap)?</TD></TR></TABLE>
So you ruled out turbo, supercharger, and H22....there's nothing left short of a complicated and difficult NA build that most likely won't work as a daily driver. What are your goals?
Why does being an auto mean there's no point to turbo it?
Old Jul 20, 2008 | 08:03 PM
Andryzzle's Avatar
i thought the main reason was that the auto F tranny was sorta weak.
Old Jul 21, 2008 | 07:32 PM
Wagonist's Avatar
Default Re: supercharging an f22b1 (Andryzzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andryzzle &raquo;</TD></TR><TR><TD CLASS="quote">i thought the main reason was that the auto F tranny was sorta weak. </TD></TR></TABLE>
Keep it at low boost.
Old Jul 21, 2008 | 08:31 PM
Andryzzle's Avatar
Default Re: supercharging an f22b1 (Wagonist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wagonist &raquo;</TD></TR><TR><TD CLASS="quote">
Keep it at low boost.</TD></TR></TABLE>
unacceptable.
Old Jul 21, 2008 | 08:39 PM
wyotecher-4-life's Avatar
HAHAHA! I highly doubt the F22 tranny is anything but tough. mine has lasted through my driving, neutral bombs and reverse drops now for 3 years straight. i been trying to kill it cause i got a nice turbo H22 fresh rebuild to throw in it. My suggestion is to build the f22 and convert the tranny to 5 speed if you must have a M/T although i would keep the A/T you will never miss a shift that means no lost races due to driver error build the A/T with a shift kit if you like. I take it that you have never driven a high horsepower A/T transmission car? its no less fun than the good ole 5 SPD.
Old Jul 22, 2008 | 08:32 AM
MN_F22B1's Avatar
Default Re: (wyotecher-4-life)
I don't mind the idea of an h22 swap but being on somewhat of a budget doesnt help when you have to buy one $2000 engine, not something you can really piece together.
as far as driving a high power a/t, before i decided to build my accord i was looking at buying a 96 camaro with an a/t and a built engine, but seeing as this will be a daily driver i don't need my tranny to blow up on me.
Old Jul 22, 2008 | 05:25 PM
sony224422's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wyotecher-4-life &raquo;</TD></TR><TR><TD CLASS="quote">HAHAHA! I highly doubt the F22 tranny is anything but tough. mine has lasted through my driving, neutral bombs and reverse drops now for 3 years straight. i been trying to kill it cause i got a nice turbo H22 fresh rebuild to throw in it. My suggestion is to build the f22 and convert the tranny to 5 speed if you must have a M/T although i would keep the A/T you will never miss a shift that means no lost races due to driver error build the A/T with a shift kit if you like. I take it that you have never driven a high horsepower A/T transmission car? its no less fun than the good ole 5 SPD.</TD></TR></TABLE>
as far as i know.. there isn't a shift kit for the f22
Old Jul 22, 2008 | 08:23 PM
twotonecivic's Avatar
Default Re: (sony224422)
best bet for boosting a stock auto f22 tranny is running a good tranny cooler.
Old Jul 22, 2008 | 09:53 PM
Default Re: (twotonecivic)
I agree there probably isnt lol its not too popular to do this sort of project but a shiftkit is easily made since all a shiftkit includes is a few aluminum blocks to replace the detent shift softeners (since a soft shift means clutch pack slippage) stiffer shift springs to make it shift at a higher RPM and a thinner pressure plate in the clutch packs to make room for one or more extra wet clutch discs. so if you know what your doin you can make a backyard budget shiftkit for next to nothin
l1bid0
12
Dec 28, 2006 08:16 AM
rusted_eyes
Honda Motorcycles
May 22, 2006 08:58 AM
DB1_559
Oct 20, 2005 12:05 AM
sohcvtec66
31
Feb 6, 2004 04:46 PM
