some ole dumb questions.
Just need some help with some of these things.
1. What are shifter bushings? Would it be smart to buy them?
2. What is Crank Walk?
3. what are these glorious polyurethane bushings I hear so much abuot?
4. I've heard of this "running water", what is it?
5. Limited Slip Diff., what is the open differential?
6. Light switches...they do what?
7. What are wheel spacers?
thats basically it for now.
[Modified by Veil_Side_, 2:12 PM 7/20/2002]
Shifter Bushing is a little rubber donut that makes the shifter shift a lot smoother, if they are old and rotting they will shift like ***, but if you get new ones or even poly ones it will shift a lot smoother
I think poly is more durable and not prone to rotting out like rubber does, I think it's slicker so certain things go smoother
Limited Slip is like Positrac on old Muscle Cars. It basically will transfer the power to the wheel with the most grip when going around turns or whatever situation would have one wheel slipping more than the other
Turn on and off lights
They are like discs with holes in them that go behind the rim and make it stick out more
mafioso102
Jan 31, 2002 04:38 AM
