AC cause overheating?
Old Jul 16, 2008 | 11:06 AM
Wazup's Avatar
Default AC cause overheating?
I have a 1990 crx SI..
I had a shop convert the AC system to 134a, it works, but now the car is overheating and surging at idle. It didnt do it before.
Could the AC be the cause?
could I just take off the belt for now, so the AC would be disconnected?
Old Jul 17, 2008 | 03:29 AM
NlCK B's Avatar
yes it can be the cause and taking off the belt will be the easiest way to find that out for sure
Old Jul 17, 2008 | 07:01 PM
pimpwagon's Avatar
Default Re: (NlCK B)
although the extra load it puts can be the cause, it shouldnt be. if you havent done it in a while id put a new oem thermostat and test the coolant. making sure to bleed all the air out of the system. if you op the rad cap and its all funky, you could have restrictions in the radiator.
pliskin679
Aug 11, 2010 01:25 AM
TcUiRvBiOc
Apr 26, 2008 06:16 PM
CivicSD
Aug 20, 2007 08:40 AM
Demon R
May 23, 2004 10:46 PM
