Skunk2 or Supertech?!?!?! please help
Old Jul 16, 2008 | 09:37 AM
MR_FIX_IT's Avatar
Default Skunk2 or Supertech?!?!?! please help
ok so i bent some valves in the head on my 2000 GS-R and now i want to replace the valves ,springs, and the retainers. Ive been pricing the skunk 2 tuner series valve train and the supertech valve train.......now the supertech stuff is a lil easer on the wallet but is it good stuff?? id like to hear from people that have actualy used thes products....thanks
Old Jul 16, 2008 | 11:52 AM
MR_FIX_IT's Avatar
Default Re: Skunk2 or Supertech?!?!?! please help (MR_FIX_IT)
the motor is stock and will never be reved past 9k......will be running a mild cam
Old Jul 16, 2008 | 12:48 PM
BMo Tuning's Avatar
STAR
Supertech is good stuff, you won't be dissapointed.
Old Jul 17, 2008 | 08:19 AM
MR_FIX_IT's Avatar
Default Re: (BMo Tuning)
thats what ive been reading.......i think im just gonna go with supertech.
Old Jul 17, 2008 | 04:30 PM
blackpeoplejump's Avatar
Default Re: (MR_FIX_IT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR_FIX_IT &raquo;</TD></TR><TR><TD CLASS="quote">thats what ive been reading.......i think im just gonna go with supertech.</TD></TR></TABLE>
Old Jul 17, 2008 | 05:43 PM
hotrod99's Avatar
Default Re: (blackpeoplejump)
Supertech
Old Jul 17, 2008 | 08:10 PM
crx-b18c's Avatar
Default Re: (hotrod99)
supertech good price good parts
Old Jul 17, 2008 | 08:15 PM
SpiderX1016's Avatar
You can't go wrong with Supertech.
Old Jul 17, 2008 | 08:28 PM
downest's Avatar
Default Re: (SpiderX1016)
I really like the skunk2 Pro Series, but I also haven't used SuperTech. You might want to use whatever matches your cams, for warranty replacement issues if something does break.
Also, skunk2 is disco'ing the tuner series last I knew, when I talked to my Skunk2 rep.
Old Jul 17, 2008 | 11:56 PM
A.E Motoring's Avatar
Default Re: (downest)
both are great
Old Jul 18, 2008 | 03:36 AM
patriot's Avatar
Default Re: (A.E Motoring)
Supertech. Tested to be compatable with atleast S2 Pro2's and a bit cheaper.
Old Jul 18, 2008 | 08:14 AM
MR_FIX_IT's Avatar
u guys made up my mind....supertech it is......thanx
Old Jul 18, 2008 | 11:42 AM
riceburner700's Avatar
we sell, install and run supertech in all our heads. reasonably priced to
Old Jul 18, 2008 | 12:21 PM
SkoundrelUSA's Avatar
cute little bastard
I've had supertech valvesprings and retainers for 26,000 miles. Still good.
Old Jul 18, 2008 | 06:36 PM
bananaketchup's Avatar
supertech FTW!
Old Jul 19, 2008 | 06:39 AM
Lubo_25's Avatar
supertech makes great valvetrain kits...just be sure to watch out which kit you get
your rocker assemblies will thank you...
Old Jul 19, 2008 | 07:03 AM
RB IMPORTS's Avatar
Default Re: Skunk2 or Supertech?!?!?! please help (Lubo_25)
supertech
Old Jul 19, 2008 | 08:28 AM
MR_FIX_IT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lubo_25 &raquo;</TD></TR><TR><TD CLASS="quote">supertech makes great valvetrain kits...just be sure to watch out which kit you get
your rocker assemblies will thank you...</TD></TR></TABLE>
care to go into detail with that.....
Old Jul 19, 2008 | 01:51 PM
OH_1fstgsr's Avatar
What about Supertech Springs and Retainers and OEM ITR Valves?
Not sure if this saves any money but the OEM valve are pretty good.
Old Jul 19, 2008 | 02:24 PM
Lubo_25's Avatar
its quite simple really stiff springs will pound away @ your precious valvetrain...
Old Jul 19, 2008 | 04:13 PM
patriot's Avatar
Last time I checked, supertech only made one set of springs available for the B-series...and I'm not quite sure why your rockers would have any trouble with them, unless their installed height means you need to modify the rockers.
And yes, a good alternative is to keep the OEM valves. The only reasons to change the valves is really to shape combustion events or to give yourself a little lighter intake valve... or if you need the insurance with a turbo and use SS valves... OR if you've bent some.
PS- crazy cam lobe ramps will kill valve seats...not necessarily the springs alone.
Old Jul 19, 2008 | 04:46 PM
4g hatch's Avatar
Default Re: Skunk2 or Supertech?!?!?! please help (patriot)
they do make 2 different sets. i think they ar different seat pressures. one is a good bit heavier and has a bit more max lift.
maybe one of the head experts will chime in to set the record straight
Old Jul 19, 2008 | 05:10 PM
97se-rblown's Avatar
Supertech FTW!
Old Jul 19, 2008 | 05:41 PM
Combustion Contraption's Avatar
SPR-H1002D is 70lbs@ 1.32" and 190lbs @ .472"
SPR-H100DR is 85lbs@ 1.32" and 266 @ .552"
Old Jul 19, 2008 | 09:20 PM
DarKStaR5's Avatar
Default Re: (Combustion Contraption)
What kind of setup would you use on either one? Gonna order me a set and need to know which one to get. thanks
