2.0L All-motor 282 WHP B-series graph Kingmotorsports
Old Jul 15, 2008 | 08:54 PM
BearsEK-KMSU's Avatar
Default 2.0L All-motor 282 WHP B-series graph Kingmotorsports
Well now that my big block 95mm stroker motor is waiting on custom pistons I built a back up motor to run in the mean time. The same bottom end as my 275 whp motor just with better headwork and pro 3's instead of pro 2's.
The build
B20z 84.5mm
BDL block guard(pulled out of the old block and reused)
used Wiseco shelf 8.25CC shelf pistons (from old motor)
Probe rods retanged for R bearings (from old motor)
new B20 crank, polished (the old motors crank was cracked)
edlebrock Victor X reworked a bit
ericks racing 72mm throttle body (punched out 1.6mm bigger)
SMSP b20 vtec header
Skunk2 Pro 3's
super tech valve springs
Pure tuning headwork (from old motor and stroker motor)
14.4:1 compression
110 sunoco race gas
Hondata s300
Old 2.0L (pro 2's) vs New 2.0L (pro 3's)
Big block vs 2.0L everything the same except the block and fuel.
Modified by BearsEK-KMSU at 11:25 AM 7/17/2008
Old Jul 15, 2008 | 09:35 PM
4doorekITR's Avatar
Default Re: 2.0L All-motor 282 WHP B-series graph Kingmotorsports (BearsEK-KMSU)
wow..sick numbers..whats the compression ratio of that bad boy if you dont mind me asking..and what kind of fuel you running in there?
Old Jul 15, 2008 | 10:30 PM
koczeka's Avatar
Congrats!
What intake U were using?
Old Jul 15, 2008 | 11:48 PM
Broken Gearbox's Avatar
Default FV-QR
insane.
tuned on what?
Old Jul 16, 2008 | 12:35 AM
greeneg2.0's Avatar
what compression are you runing .
Old Jul 16, 2008 | 02:56 AM
stealth50k's Avatar
Thats also with a b20 crank to. A monster
Old Jul 16, 2008 | 04:12 AM
Default Re: (stealth50k)
build list edited
Old Jul 16, 2008 | 05:10 AM
2fastGSR's Avatar
King of the One Liners
Default Re: (BearsEK-KMSU)
Wow , cant wait to see the 86x95 back up and running . . .
Old Jul 16, 2008 | 05:33 AM
FST GSR 1's Avatar
Old Jul 16, 2008 | 05:41 AM
4F_ Mugen CoL's Avatar
Default Re: 2.0L All-motor 282 WHP B-series graph Kingmotorsports (4doorekITR)
Wow that is serious, good luck with the motor
Old Jul 16, 2008 | 05:54 AM
PURE Tuning's Avatar
Great numbers again.... Good luck this weekend
Old Jul 16, 2008 | 05:55 AM
Shadowz7429's Avatar
Awesome figures dude can't wait for the other build!
Old Jul 16, 2008 | 06:25 AM
mar778c's Avatar
Community Builder
Community Influencer
Hella nice recovery.
Old Jul 16, 2008 | 06:27 AM
allmotaeg6's Avatar
wow!always pulling good numbers..was it tuned by you as well?
Old Jul 16, 2008 | 06:29 AM
goforbroke's Avatar
MEAT PATTY
Default Re: 2.0L All-motor 282 WHP B-series graph Kingmotorsports (mar778c)
I'm just wondering if you have an old graph of your previous motor that made 275whp so we can compare the curve if you over lay them together.
Old Jul 16, 2008 | 06:33 AM
Default Re: 2.0L All-motor 282 WHP B-series graph Kingmotorsports (allmotaeg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotaeg6 &raquo;</TD></TR><TR><TD CLASS="quote">wow!always pulling good numbers..was it tuned by you as well? </TD></TR></TABLE>
Yes I tuned it myself.
EDIT:
Graphs added to original post
Modified by BearsEK-KMSU at 3:33 PM 7/16/2008
Old Jul 16, 2008 | 07:28 AM
N20civicB18's Avatar
nice numbers
Old Jul 16, 2008 | 10:32 AM
k20coupe's Avatar
nice numbers
Old Jul 16, 2008 | 02:55 PM
MikeySpec's Avatar
Default Re: (k20coupe)
Good Job Mike!! Good luck at the track out there. We are planning on doing test and tune at GLD in a couple weeks, maybe we'll see you there?
Old Jul 16, 2008 | 03:37 PM
alterdcreations's Avatar
Default Re: (MikeySpec)
nice
did you do any additional mods to the intake manifold and what did you do?
Old Jul 16, 2008 | 06:39 PM
egb18c5's Avatar
Default Re: (alterdcreations)
nice numbers, i see u guys are tryin to extract a lot of numbers from a B series before the K. hopefully we'll see more numbers!
Old Jul 17, 2008 | 06:08 AM
AWOC's Avatar
Default Re: (egb18c5)
any graphs of the pro 2's
Old Jul 17, 2008 | 06:30 AM
Default Re: (AWOC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWOC &raquo;</TD></TR><TR><TD CLASS="quote">any graphs of the pro 2's</TD></TR></TABLE>
The old drag car motor had pro two's the comparison is on my first post.
Old Jul 17, 2008 | 07:06 AM
junkyard racer's Avatar
pics of the engine/manifold?
Old Jul 17, 2008 | 07:49 AM
FST GSR 1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BearsEK-KMSU &raquo;</TD></TR><TR><TD CLASS="quote">
The old drag car motor had pro two's the comparison is on my first post.</TD></TR></TABLE>
I got your text late, call you later. Nice numbers from last night, sounds like humidity may be holding back a tenth and 1-2 MPH. Nevertheless, welcome back.
