Rear Camber Washer question...(did search)
Old Jul 20, 2002 | 09:03 AM
Cone's Avatar
Default Rear Camber Washer question...(did search)
I searched and found out all I needed to know except one thing about the rear camber fix with washers. After I install the washers (2 3/8" per bolt for my prokits) do I still need a rear alignment, or just a front alignment? Will I need a rear alignment to fix the toe (if it is even adjustable on the rear)? I want to know because the shop I am going to charges $52 for front alignment and $99 for front and rear. I'd like to save $47 if all I need to do is put in the washers. I would like to know by Monday. Thanks a lot.
-Andrew
Old Jul 20, 2002 | 09:33 AM
TurbothisLS's Avatar
Default Re: Rear Camber Washer question...(did search) (Stealth 95 GS-R)
man $100 for an alignment?
Old Jul 21, 2002 | 12:12 PM
Cone's Avatar
Default Re: Rear Camber Washer question...(did search) (Teken)
thanks for the reminder and help.
-Andrew
swizz977
10
Dec 23, 2011 09:07 PM
revolt_allmotor
Suspension & Brakes
Nov 6, 2005 09:04 PM
EK k kay
Suspension & Brakes
May 17, 2005 09:39 AM
91_hatch_si
Dec 30, 2002 09:15 PM
01CWITR
Aug 6, 2002 05:32 PM
