electronic damping force control!!!!!!!
Old Jul 15, 2008 | 03:07 PM
d16a9_edcivic's Avatar
Default electronic damping force control!!!!!!!
I was wondering are there any coilover systems available with electronic damper contol. Tein do systems from 92> not [freak]ing ef though. Typical.
Any help welcome. Cheers!
Old Jul 15, 2008 | 03:13 PM
RyanA's Avatar
Default Re: electronic damping force control!!!!!!! (d16a9_edcivic)
Why not just get the 92-95 setup and put 92-95 front forks on?
Old Jul 17, 2008 | 06:03 AM
Default Re: electronic damping force control!!!!!!! (RyanA)
What about the rear. Will the eg shcoks fit the back of the ef or is there modification needed?
Old Jul 17, 2008 | 07:25 AM
RyanA's Avatar
As long as it's an 89-91, they are a direct bolt on. If you have an 88, you need to change your lower control arm to the 89-91 piece.
Old Jul 18, 2008 | 06:13 PM
red_ef's Avatar
if you get pillowball upper mounts with the tein super street ef dampers and find an older edfc it will work
sasinorm01
Jul 12, 2016 08:42 AM
VeilSide_Mas
Feb 10, 2006 08:36 AM
EPrepCivic
May 19, 2005 07:30 AM
red civic standard
Jan 19, 2004 06:08 PM
