what dose a p28 ecu check for before engin start? cel on before car is started
i have cel light on some times before the engine is started and stays on. i can drive fine for hours with no cel but when i shut it off and go to restart (i let it sit in the on postion and what for the cel to go out before i atempt to start) the car after 15min the cel is on and dose not clear some times. it will go off on its own when it feels like it but why is it doing this. probe the connecter and solid cel no flashes.
Modified by mkw1 at 6:13 PM 7/15/2008
Modified by mkw1 at 6:18 PM 7/15/2008
the fuel pump primes and the relay clicks but usally when the relay clicks and the cel light will go out, but some times it stays on after the click. what is cold solder joints? i never heard of that.
a cold solder joint is a solder that doesnt penetrate the two surfaces well, and therefore doesnt make a good electrical connection
it will work sometimes, and not work at other times.
cold solder joints become a biG problem when vibration is introduced
you know how ppl are telling you to check your main relay? guess why.... because the solder joints are crappy from the factory and rattle loose, causing intermittent startup issues.
91ef_civic
Mar 11, 2011 08:39 AM
forcefed22
Sep 18, 2008 08:18 PM
blackeg
Apr 3, 2007 07:07 AM
BOOSTEDgreeneg
Sep 15, 2005 07:27 PM
