painting valve covers
I don't have a sandblaster but do you think jasco would work to strip the paint off the old VC? can i just use spray paint? would that work?
also what are other little things i could paint myself and such to make the engine bay or interrior a little more spice
what kinda paint do i use on the VC?
Modified by lilvietboy at 3:15 PM 7/15/2008
There is this stuff at the autoparts store called airplane stripper.
Works awesome.
May want to use a high temp paint.
Maybe you could get away with normal paint, but it gets a little warm.
I have not used a regular paint.
Works awesome.
From: somewhere in the d, mmm stake, mmm country fried stake
i used a basecoat/ clear cot...cant go wrong...as long as it is really clean forehand...i used aircraft remover...sanded with a 320 grit...then 400...then used high temp can primer...then wetsanded smoot...then basecoated....cleared...and baked at low temp for about an hr...
FBP Si 2000
Mar 3, 2003 07:46 PM
