Things keep getting better
Old Jul 20, 2002 | 07:15 AM
hybridbmw's Avatar
Default Things keep getting better
I posted before about my tach problem and temp guage problem. I know the distributer needs to be replaced and i havent had a chance to check the temp guage yet to see if its a loose wire. But last night has just put the iceing on the cake. As im driving home last night my tach just stops working. Then i notice that my guage cluster lights and my stereo lights are getting dimmer, then my headlamps start getting dimmer, then the stereo goes out, and finally the car just stalls and i coast until im about 4 blocks from my house. All i have to say is im really pissed off right now, i cant believe all this crap is happening at once, especially when i have to pay for my tuition and books within the next 3 weeks. I'm guessing that now my alternater is probably gone and i have to replace that too. Do you guys think that is the problem? If it is, do i just get a alternator for a b16a2 from the del sols or the civic Si's? Sorry about the semi long post, i just need to rant about this, im sure most of you guys understand. Thanks!
Old Jul 20, 2002 | 07:19 AM
crx(gator)'s Avatar
Default Re: Things keep getting better (speedaholic)
sounds like your alternator to me...as far as replacement, im not too sure...
Old Jul 20, 2002 | 08:59 AM
hybridbmw's Avatar
Thanks for the reply crx gator, does anyone know which alternator i need for my 1st gen b16? I'm guessing that they are all the same, but im not too sure. Thanks!
Old Jul 20, 2002 | 05:55 PM
crx(gator)'s Avatar
TTT...cause alternators suck... when they are broken...
Old Jul 20, 2002 | 07:10 PM
02WRX's Avatar
Default Re: Things keep getting better (crxgator)
You can use any obd-0 or obd-1 b-series alternator. I used a 94 GSR alternator because they put out more amperage (90) than do the 91 LS (65).
Eric
Old Jul 22, 2002 | 09:57 AM
hybridbmw's Avatar
Default Re: Things keep getting better (90CivicEX)
Thanks for the replies, i just ordered my alternator from autozone. $199.00 plus a $105.00 core charge. Gotta love credit cards
Old Jul 22, 2002 | 12:10 PM
REDBARON's Avatar
Are you sure that the alternator is out? I had the exact thing happen to me. I looked at the alternator and the wire thats held together by a bolt was loose. I took the bolt off and cleaned the terminals, and then just bolted it back on. Hasn't happened again since. Just making sure you actually confirmed that the alternator was bad and not just assumed.
Latz.
crxjarred
Feb 13, 2010 09:30 AM
99CivicSiBrian
Feb 24, 2006 03:32 PM
LillDragun
May 31, 2002 03:15 PM
