ghetto d16a6 buildup question...
you can use either
what fuel rail are you using with the z6 mani?
i would stick with the same fpr for the same fuel rail
the z6 one will give you higher fuel pressure because its a Sohc Vtec fpr
so i would suggest to just stick with the a6
if u usin the A6 long block. use the A6 FPR.....
if u using the Z6 longblock use the Z6 FPR...... in other words. dont use the Z6 PFR unless u got vtec.,,, ull be running ricch......
well...i have a b&m fpr for it anyway, plus ill be having a crower cam, and the manifold will be ported, as well as the other air mods...(i/h/c/e)...
EGandDArida
Nov 12, 2008 08:18 AM
crx_91si
Oct 4, 2003 07:54 AM
photonjedi808
Jul 21, 2002 02:25 PM
