intermittant headlight failure
Old Jul 15, 2008 | 07:07 AM
rmckim's Avatar
Default 1993 Si intermittant headlight failure
Anyone know how to TS headlights that wink off and on at random? they may stay off for 3 seconds or 300 seconds. scary stuff on a dark road... tapping or flicking the switch does NOTHING, neither does road vibration. Very strange, never heard of this before. It happens and you go WTF is this !!!
TYVM
Modified by rmckim at 11:24 AM 7/15/2008
Old Jul 15, 2008 | 03:15 PM
Scheizty's Avatar
Default Re: 1993 Si intermittant headlight failure (rmckim)
I had headlights that came on for a day, then went out. If I reseated the plugs, they would work for a day, then go out again. Brand new bulbs were DOA. Try bulb replacements.
Old Jul 15, 2008 | 04:19 PM
tofast4uh22's Avatar
i have had this exact problem before. shut off on me on a dark road and had to keep turning on and off then they would finally come on. i checked and replaced everything. finally i found it to be the relay that is under the hood on the passenger side. replace this and let me know.
Old Jul 15, 2008 | 06:05 PM
DR1V3N's Avatar
Loose or bad ground wire?
Old Jul 15, 2008 | 06:22 PM
Kronn 98SH's Avatar
Default Re: (DR1V3N)
check the socket the bulb plugs into. The leads on mine were corroded and bent. Scraped 'em off and bent 'em back into place and never had a problem after. (Went through 6 aftermarket bulbs in 4 weeks).
hotaccord243
May 29, 2008 01:00 PM
EK VTi
Acura TL, RL & ZDX
Mar 6, 2006 08:22 AM
soberstan
Oct 19, 2004 04:08 PM
Accorddrver
Apr 27, 2004 09:41 AM
CrazieLude
Jun 20, 2003 09:58 PM
