My 5 Speed, LS/VTEC Conversion Build, Lots of Pics!
Old Jul 15, 2008 | 05:19 AM
stillrockin18s's Avatar
Default My 5 Speed, LS/VTEC Conversion Build, Lots of Pics!
NEW PICS 2/11/09
This thread is put together to show the process of basically stripping one car and building another.
This thread will show a lot of pictures of different parts, cars, and after different processes. The process may go on for a while, I am on a limited schedule, limited budget. Target finish date is by next spring or sooner.
5 Speed Donor Car
Before
Current
93 Integra 5 Speed LS, 120K, black interior – this car has twice “R” titled, and started to rust underneath, so it was time to get rid of the car and take it to the yard. It was actually my wifes car she had since ’99.
And convert another car to 5 speed, ls/vtec & a lot more
92 Integra Automatic, LS, 138K, tan interior, purchased the car for $300 with a broken timing belt, fixed it, wife drove it as is for 3+ years everyday. Little bit of rust around the rear ¼’s, but that won’t be a problem.
Looking to build a possible weekend track car, but still a street drivable car. Nothing real serious, just something to have fun in. I am trying to use all the parts I can off the “donor” car.
PARTS
Donor Engine/5 Speed Trans (also have the pedals and everything else for 5 spd coversion)
5 Speed Axles, Sprint 2.5in lowering springs, KYB struts, sprint front camber kit
Complete B16 head being disassembled for some aftermarket goodness, shaved and paint valve cover when I was bored
Replacement hood
WW RS Front lip
Pulling the harness in donor
Thanks for my boy Postman for all the assitance
Here are some of my other build threads for other cars I have done...
DA Show Car https://honda-tech.com/zerothread?id=2146778
CD5 Accord https://honda-tech.com/zerothread?id=1615483
https://honda-tech.com/zerothread?id=1958716
CG5 Accord https://honda-tech.com/zerothread?id=2146787
Old Jul 15, 2008 | 08:38 AM
dirtyharryhatch's Avatar
A Digital Frontier
i hope ur not using the stock ls 5 speed tranny?
Old Jul 15, 2008 | 08:50 AM
Default Re: (dirtyharryhatch)
I am for now unless the right deal falls upon me
Old Jul 15, 2008 | 08:57 AM
A Digital Frontier
Default Re: (stillrockin18s)
cool cool hopefully everything goes great. good luck
Old Sep 1, 2008 | 06:10 AM
So I have been really bad at putting updates up and taking pictures. I've found out my wife is pregnant, she's been keeping me pretty busy, haven't had alot of time.
The donor engine has been completely stripped. Block has been, cleaned, sanded/suffed, primered, painted, cleared, honed and starting to put together the block as we speak. I am taking everything else apart and painting it the same way.
New parts list
Rywire LS/Vtec Sub Harness
Oil Filter Adapter Plate
P30 B16 Pistons
Golden Eagle Dowel Rods
Golden Eagle Head Studs
APR Rod Bolts
Bearing Set
GSR Oil and Water Pump
Current Form
Hopefully by next weekend the crank and pistons will be re-installed, then to start working on the head again. Currently going through and double checking the clearances and piston ring gaps.
Modified by stillrockin18s at 10:46 AM 9/1/2008
Old Sep 1, 2008 | 06:39 AM
American.Graffiti's Avatar
Nice to see the effort on the bounce back.
Old Sep 4, 2008 | 08:36 AM
bump
Old Sep 4, 2008 | 06:17 PM
Updates? you know H-T is hungry for pictures.
Old Sep 7, 2008 | 06:02 PM
Brice.Hayden's Avatar
I hope none of the original parts end up on this new project.
Old Sep 8, 2008 | 08:01 AM
Default Re: (Brice.Hayden)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brice.Hayden &raquo;</TD></TR><TR><TD CLASS="quote">I hope none of the original parts end up on this new project. </TD></TR></TABLE>
As far as??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by American.Graffiti &raquo;</TD></TR><TR><TD CLASS="quote">Updates? you know H-T is hungry for pictures.</TD></TR></TABLE>
Soon, only thing I really did this weekend is to install the crank. Awaiting new piston rings from Honda
Old Sep 11, 2008 | 01:46 AM
The rings and bolts came from Honda yesterday that I needed. Update soon.
Old Sep 11, 2008 | 04:38 AM
92teginsc's Avatar
make us proud!
Old Sep 11, 2008 | 08:48 AM
Default Re: My 5 Speed, LS/VTEC Conversion Build, Lots of Pics! (stillrockin18s)
Added links to some of my other work on bottom of first post
Old Sep 14, 2008 | 07:36 AM
92teginsc's Avatar
Old Sep 15, 2008 | 05:23 AM
Default Re: My 5 Speed, LS/VTEC Conversion Build, Lots of Pics! (92teginsc)
Bearings/Pistons/Crank are installed. I forgot to order a bottom end gasket kit, so now I have to wait for that to arrive to have the block completely done. I will snap some new pics of the block when I get home.
I've also ordered all the fittings and oil line over the weekend.
I've been working 10-12 hours on saturdays for the past month or so. Thats slowed down the weekly progress since that was my "work on car day".
Old Sep 15, 2008 | 03:21 PM
Cleaned the transmission really well, removed what I needed to, scuffed, painted and cleared.
Old Sep 17, 2008 | 04:45 AM
Gasket set should be on my doorstep Friday. Hopefully some more updates this weekend.
Old Sep 22, 2008 | 01:10 PM
The bottom end is done, all new gaskets installed. Now ready to focus on the head, I will be dropping it off at the machine shop for cleaning and milling tomorrow or wed.
also refinished the non-abs booster and master cylinder that I will be using, the fluid cup was taken apart and scrubbed.
Old Sep 30, 2008 | 12:00 PM
head with VC
head without V/C
intake manifold, throttle body, and polished OEM fuel rail
What each piece looks like before putting it back together, all pieces are cleaned out and all seals/gaskets are being replaced
Next, I need to order a timing belt, .045 head gasket (head was milled), and lots of other misc things. Can anyone make a suggestion on ECU setup??
Buy my parts in my FS thread so I can get this done by March, LOL!
Old Oct 2, 2008 | 01:37 PM
fastwanabe's Avatar
Better days? I hope your kidding. Im surprised that you can build a motor yet rice out a vehicle. GL
Old Oct 2, 2008 | 01:57 PM
290allen's Avatar
Default Re: (fastwanabe)
why does the way his car looks bother you? get some hobies
Modified by 290allen at 3:09 PM 10/2/2008
Old Oct 2, 2008 | 03:49 PM
Default Re: (290allen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastwanabe &raquo;</TD></TR><TR><TD CLASS="quote">Better days? I hope your kidding. Im surprised that you can build a motor yet rice out a vehicle. GL</TD></TR></TABLE>
1. It was my girls (now wife) car, she picked the parts, I did the work, I never liked it. Thats the reason that its parted out now. Its been sitting for years.
2. Just because someone has a riced out car doesn't mean they have no ability to build a car. I have been working on Honda's specifically since 1995 when I was 15 years old (and have owned numerous DA's, accords, civics). You have no idea how much work I have done, or my skills. I do EVERYTHING myself and with my best friend which is a honda tech. Sorry if my cars aren't designed by your cookie cutter style.
My suggestion to you is to GTFO and find something else to do.
Old Oct 6, 2008 | 05:24 PM
Started mocking up the "tucked" engine harness, still needs finished up with loom and such. I will post pics with it on the engine soon.
Old Oct 6, 2008 | 06:34 PM
nice work..would like to see some more car pics
Old Oct 6, 2008 | 07:04 PM
hellshock2182's Avatar
Seriously dude, go [freak]ing hang yourself with fishing line.
To the creator of the thread. Good job man way to bring one back from the dead by using it's parts on another. Keep up the good work.
