Trany oil, what do you use?
Old Jul 20, 2002 | 06:28 AM
1990hondaHF's Avatar
Default Trany oil, what do you use?
There is only one topic about this important info....now there are two. Thanks.
Old Jul 20, 2002 | 08:21 AM
1.8Tities's Avatar
Default Re: Trany oil, what do you use? (1990hondaHF)
I used Honda MTF...
Old Jul 20, 2002 | 10:30 AM
Biffyjr's Avatar
Default Re: Trany oil, what do you use? (4thGSi)
Fully synthetic for me. It won't let me vote?
Old Jul 20, 2002 | 01:48 PM
johnzm's Avatar
Default Re: Trany oil, what do you use? (Biffyjr)
redline, thats all ill ever use
Old Jul 20, 2002 | 07:25 PM
USDM 4G VTEC's Avatar
Havoline!!!!!!!!
Old Jul 20, 2002 | 09:00 PM
RexB16's Avatar
Default Re: Trany oil, what do you use? (JDM EF9)
hey all u synthetic guys, synchros need friction in order to operate properly. that is precisely why honda mtf is a semi-synthetic blend and not a full synthetic. so keep using full synthetics and prepare to replace quite a few trannies.
Old Jul 20, 2002 | 10:29 PM
johnzm's Avatar
Default Re: Trany oil, what do you use? (RexB16)
hey redline oil has friction modoiers added so it actually sychs gears better than plain oil
Old Jul 21, 2002 | 01:20 AM
RexB16's Avatar
Default Re: Trany oil, what do you use? (johnzm)
i am talking about the guys running **** like mobil 1.
Old Jul 21, 2002 | 03:50 AM
REX VT's Avatar
Castrol 10W-40 Semi-syntehtic
Old Jul 21, 2002 | 04:37 AM
johnzm's Avatar
yes, that is true. anyone running a full synthetic MOTOR OILD shoulod dran that siht and use a plain non detergent 10-30
Old Jul 21, 2002 | 09:20 AM
dohcsideSi's Avatar
only honda mtf.
as everyone said don't use a full syn, or just plain motor oil
Old Jul 21, 2002 | 04:56 PM
keithv's Avatar
Default Re: Trany oil, what do you use? (dohcsideSi)
i use 2 stroke motorcycle oil.
Old Jul 21, 2002 | 05:40 PM
MrTodd's Avatar
Default Re: Trany oil, what do you use? (breaka_1_9)
Honda MTF is the ONLY way to go. Redline is prolly a little bit better to use than part-synthetic motor oils, but not nearly as good as the MTF. Believe me, I've used regular motor oils, part-synthetic motor oils, full-synthetic motor oils, redline MTL, and now finally Honda MTF.
Not only is it proven to work better in every situation than any other oil, you can actually feel the difference. Right after I switched from redline to the Honda stuff, my tranny felt so much better!
Coolcat55
26
Dec 6, 2013 10:02 PM
RACEPAK
Jun 18, 2010 11:46 PM
Zedx148
Mar 6, 2007 10:33 AM
Brian-Brian
Oct 15, 2003 05:40 PM
-BlueGSR-
May 25, 2003 03:40 PM
