Midori EJ6 Build from Hawaii
Old Jul 14, 2008 | 10:16 PM
JDMInspired's Avatar
Default Midori EJ6 Build from Hawaii (56K Beware)
Waddup HT. I'm posting this build up for my friend since he's lazy to register himself on the boards. We are building up a 1996 Civic DX Hatchback with a JDM B18C Swap. Comments/Suggestions welcomed.
ATTN: I retrieved my login info to my original account (jamescardenas07). I will be using that account to update the build thread and using this account ONLY to update this post.
Master Index
Page 1
-D16Y7 Pull
-Hasport Mount Install
-New Parts
--Exedy Replacement Clutch
--ARP Flywheel Bolts
--OEM Top End Gaskets
--OEM Timing Belt, Water Pump & Tensioner
--JDM N1 Crank Pulley
--MSD 6AL & Plug Wires
-OEM Timing Belt, Water Pump & Tensioner Installed
-JDM N1 Crank Pulley Installed
Page 2
-New Parts
--Rywire Harness
--AEM Hybrid Intake
--DC Sports 4-1 Header
--Samco Hoses
--OEM Si Shift Linkage
--Energy Suspension Shifter Bushings
--OEM Bottom End Gaskets
--NGK Iridium Spark Plugs
-Exedy Clutch Installed
-DC Header Installed
-Motor Dropped In
-Rywire Harness Installed
-Samco Hoses Installed
-NGK Iridium Spark Plugs Installed
Modified by JDMInspired at 7:03 PM 8/11/2008
Default Re: Midori EJ6 Build from Hawaii
Prepping the engine bay, A/C removed
Pulling the D16Y7
D16Y7 is out!
Before & After
Hasport Mount install
The new motor. Thanks HMO!
The Builders
Me in the bay, owner to the right
Trailmix Bars & Arizona Green Tea. Always good after pulling a motor.
Modified by JDMInspired at 9:34 PM 7/14/2008
Old Jul 14, 2008 | 10:32 PM
Mr Fatty's Avatar
Default Re: Midori EJ6 Build from Hawaii (JDMInspired)
nice! Midori ftw!
Old Jul 14, 2008 | 10:34 PM
How do i remove this to put in the new shifter linkage?
Also, which clutch line do i need (the line that goes between the firewall hardline to the slave)? And for the drivers side hasport mount, the current stud assembly on the the itr block doesn't line up with the new mount. Which car can i get a compatible one out of?
Modified by JDMInspired at 10:20 PM 7/14/2008
Old Jul 15, 2008 | 12:32 AM
lsveeee's Avatar
was this car from oahu btw build looks mean keep us updated
Old Jul 15, 2008 | 12:54 AM
Default Re: Midori EJ6 Build from Hawaii (lsveeee)
Yep. It was originally from Oahu. I think it had a K20 in it at some time.
Old Jul 15, 2008 | 02:57 AM
dkeh3's Avatar
move the rubber piece back, and theres this pin you use a 10mm bolt and bang the **** out of it. it aka "the bitch pin"
Hope that helps you out.
Old Jul 15, 2008 | 04:16 AM
Linh.'s Avatar
Default Re: (dkeh3)
use a punch to get it out.
Old Jul 15, 2008 | 10:35 AM
Irritated_Onion's Avatar
http://www.performanceforum.co....html
Old Jul 15, 2008 | 10:48 AM
Default Re: (Irritated_Onion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkeh3 &raquo;</TD></TR><TR><TD CLASS="quote">move the rubber piece back, and theres this pin you use a 10mm bolt and bang the **** out of it. it aka "the bitch pin"
Hope that helps you out.</TD></TR></TABLE>
Thanks! We will try doing that.
Anyone know anything about the clutch line and stud assembly?
EDIT: We found what we need for the stud assembly but not for the clutch line.
Modified by JDMInspired at 10:14 AM 7/15/2008
Old Jul 15, 2008 | 11:38 AM
ImportechPerformance's Avatar
Damn thats ghetto...and not so smart.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMInspired &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by JDMInspired at 9:34 PM 7/14/2008</TD></TR></TABLE>
Old Jul 15, 2008 | 11:57 AM
Default Re: Midori EJ6 Build from Hawaii (ImportechPerformance)
Haha yep. We knew it was but we didn't care for the motor anyways.
Old Jul 15, 2008 | 08:44 PM
Some new parts
-ARP Flywheel Bolts
Removing the crank pulley
Crank pulley removed
Timing Belt, Water Pump & Tensioner Replacement
N1 Crank Pulley installed. Yes we know we didn't put back the plastic shields. We are still waiting for the side engine mount studs to come in
Also, I'm gonna send out the engine harness to Rywire soon.
Modified by JDMInspired at 9:53 PM 7/15/2008
Old Jul 16, 2008 | 02:05 AM
fsks.turboek4's Avatar
I hope with that reply about the shift linkage helped you ( I was at my friends house on his account lol)
and ditched the B foo!. GO K!!!!!!!!
I wish my EK4 was midori yoo
Old Jul 16, 2008 | 03:52 PM
defnu's Avatar
Default Re: (fsks.turboek4)
great shots. great project. cool
Old Jul 16, 2008 | 06:44 PM
808Army's Avatar
B was best i could go K would cost me 2 much. thanks for comments
Old Jul 17, 2008 | 02:39 AM
^That's the owner there folks. No more updates until Monday.
Old Jul 17, 2008 | 03:55 PM
B18CUL8R's Avatar
nice work
i get family on kauai. i used to race bmx at nawiliwili when i was a kid. that was a looooong time ago lol
Old Jul 17, 2008 | 08:24 PM
808Army's Avatar
bmx track kapa side now. never been there for long time
Old Jul 18, 2008 | 11:50 AM
hectic57's Avatar
this car would be spankin other cars at mana when its done....especially the guy with the black shirt who's standing next to the hoist...lol..good luck with swap!
Old Jul 18, 2008 | 10:04 PM
808Army's Avatar
do i know u hectic57? wat u drive
Old Jul 18, 2008 | 11:36 PM
hectic57's Avatar
Default Re: (808Army)
yea miles...i drive a civic.....and a tacoma....haha
Old Jul 18, 2008 | 11:59 PM
808Army's Avatar
oh ok now i know. u drive same thing as me but i got hatch.
Old Jul 20, 2008 | 10:04 AM
lemme guess daryl d?
Old Jul 21, 2008 | 01:26 PM
hectic57's Avatar
no
