what made my rear drums that made my front brake not work?
i need a hand here i just change my rear drums on my 91 hatch which was a pain in the ***, but everything came out right, but when i took it out the driveway i couldn't stop when i was pushing down the brake pedal, the brake pedal felt real loose, i check the brake fuel, that was full, i check the front brakes there still good, so what i did wrong when i was change my rear drums that made my front brake not work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bobjohnson »</TD></TR><TR><TD CLASS="quote">Did you bleed the brakes?</TD></TR></TABLE>
x2. what he said. when air is in the system brakes dont tend to work as well. you need another person and a 10mm. should take less than ten minutes.
yes i did bleed the brakes, but also theres brake fluid coming out from the drums must have torn wheel cylinder, ill check it and replace it so it must be the problem, well thanks
immajackuup
17
Jun 2, 2008 09:46 AM
darwin22
Aug 18, 2004 12:55 PM
