92 accord ex a/c in need of help
Old Jul 14, 2008 | 06:46 PM
lilo_goki's Avatar
Default 92 accord ex a/c in need of help
okay, my a/c is not blowing so cold, just bought the car, on my passenger side, the a/c blows colder than my driver side, don't knoe what's causing this. also took it to a shop and the mechanic's said something might be clog up. what could it be?
Old Jul 15, 2008 | 08:46 AM
99accordFX's Avatar
Default Re: 92 accord ex a/c in need of help (lilo_goki)
okay get a mechanic to check you freon levels, that be the first thing to do. Also get him to put some ac dye in the system to help with leak searches. The reason the passenger side is colder is because the evaporator is on the passenger side. the driver side is further away so the air has time to warm up going threw the vent ducts. But with a good charge it should not be to noticable.
Old Jul 15, 2008 | 08:54 PM
lilo_goki's Avatar
alright i'll check on freon level, and check for leaks. any other idea's.
Old Jul 17, 2008 | 04:41 PM
lilo_goki's Avatar
alright i just reflush the system and put in new freon, i put in 3 bottles of r134a freon, it's still not cold, it's kinda weird. well when i turn on the a/c, the level of freon goes down to danger, when i let the a/c button off, it slowly climps back up, what is wrong. any idea??
Old Jul 17, 2008 | 08:16 PM
lilo_goki's Avatar
bump!!
Old Jul 17, 2008 | 08:35 PM
phootbag's Avatar
Default Re: (lilo_goki)
The vehicle needs to be charged to the correct level according to the vehicles service information. There is a specific amount. Too little, poor performance, too much can have some similar effects as well.
I agree that refrigerant levels being too low will most likely cause your symptom. Seen it a hundred times.
Old Jul 18, 2008 | 10:53 AM
lilo_goki's Avatar
so i need more freon then right? cause it's not getting cold at all after 3 bottles of freon, and how much freon for a 92 honda accord ex, just bought the car, have no idea.
Old Jul 18, 2008 | 05:19 PM
phootbag's Avatar
R134a is a greenhouse gas. I think it should be illegal for aftermarket automotive resource stores to sell any refrigerant to anyone who isn't A/C certified for automotive systems. I highly recommend paying a shop to do it for you. Not only for the health of your car, your pocket book but for the environment as well.
Old Jul 21, 2008 | 09:27 PM
lilo_goki's Avatar
okay, this is what i found out, no freon on low but a lot on high, when i press on the vavle for high side, lot's of freon came out, but for the low side, none. i heard it could be the evaporator or the expansion vavle, something like that. what could it be.
Old Jul 22, 2008 | 10:25 AM
lilo_goki's Avatar
bump!!
Old Jul 22, 2008 | 06:33 PM
lilo_goki's Avatar
alright got it fixed today, it was the evaporator that was clog, change that and put in a new reciever drier and everything works great now.
Nisif
Jul 27, 2012 07:30 AM
celluloidheros
Jun 24, 2012 08:43 AM
Seoul Survivor
Jul 31, 2009 10:04 AM
