yup, another DIY Homemade ITB post.
Old Jul 14, 2008 | 06:02 PM
paton5g's Avatar
Default yup, another DIY Homemade ITB post.
here we go another set of homemade throttle bodies. I hope to be a little different with this project. Not many Honda enthusiasts in my area have ITB's. Plus I always liked high RPM screamer engines. So these will add a nice element to my soon to be swapped LS-VTEC with 12.0:1 CR.
I'm going away from the traditional vacuum manifold. I think it's a waste of time and money (if you have to buy one). IMO there's no reason why the plumbing can't all be done on the manifold itself. This saves clutter and hoses hanging everywhere. The plumbing will end up on the underside of these so it'll be clean on top. These arn't finished yet, so bare with me. I still have to plumb in the MAP, setup the IAT sensor and a few other things.
I picked up the 954 throttle bodies off ebay for $37.15 CAD and the hardware store bits (including the rubber couplings intended for ABS piping) for about $25.00. I gave the welder 16 cans of Guinness... and he provided the aluminum pipes!
I don't know what kind of extra WHP these will gain me. Some people on here say they get like 15 or 20 WHP from homemade ITB's. But I think I'll shoot for a more realistic 5 WHP... maybe.
I'll post the pics of the construction and my motor when I find my other camera.
Old Jul 16, 2008 | 05:50 AM
jmoney45's Avatar
Default Re: yup, another DIY Homemade ITB post. (paton5g)
ttt
Old Jul 16, 2008 | 05:57 AM
d15Beta's Avatar
wana see the results
specially with the statement " vacuum log =waste of time and money "
it is doable.. but id like to see the result
Old Jul 16, 2008 | 06:12 AM
Simmerman's Avatar
Default Re: (d15Beta)
In for the result.
Old Jul 16, 2008 | 06:25 AM
goforbroke's Avatar
MEAT PATTY
Default Re: (Simmerman)
Do you have a a side angle picture with the runners meeting up to the ITB's?
Old Jul 16, 2008 | 07:54 AM
DR1V3N's Avatar
Looking forward to the results
Old Jul 16, 2008 | 10:10 AM
3gcvcd16's Avatar
How long are they?
Old Jul 16, 2008 | 12:20 PM
GhostAccord's Avatar
Default Re: (3gcvcd16)
Those are some nice welds for a few pints of the dark stuff
In too see how they work without a vacuum log.
Old Jul 16, 2008 | 06:55 PM
paton5g's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d15Beta &raquo;</TD></TR><TR><TD CLASS="quote">wana see the results
it is doable.. but id like to see the result </TD></TR></TABLE>
yeah i know. but i think i'm on to something. wait no, I AM on to something. you'll see.
thanks for checkin' it out guys. i'm away for a week this weekend, but when i get back i'll be abl to finish them in a day or so.
Old Jul 16, 2008 | 10:41 PM
clem kevin's Avatar
do you have more pictures of it in your lap?
Old Jul 17, 2008 | 03:17 PM
paton5g's Avatar
Default Re: (clem kevin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clem kevin &raquo;</TD></TR><TR><TD CLASS="quote">do you have more pictures of it in your lap? </TD></TR></TABLE>
that can be arranged buddy...
Old Jul 17, 2008 | 03:39 PM
paton5g's Avatar
Default Re: (paton5g)
right so i took some more photos for those of you who are interested. after looking at the photos i concluded that i took them with the camera on an angle. because of this it looks like some of the tubes are on a wicked angle, but rest assured... they line up quite nicely.
the two on the right side are somewhat off, but only by a few mm or so. no biggy. i guess i could port out the pipes to make a nice smooth path, but i'm not worried about it.
i even included a photo of my lap... i'm sure my my wife will be confused.
they'll be done in a week or so... stay tuned.
Old Jul 17, 2008 | 09:11 PM
lude98SH's Avatar
looks cool. What did you just cut a factory manifold and weld to it ?
What size are the tubes that were welded ?
Old Jul 18, 2008 | 01:13 PM
paton5g's Avatar
Default Re: (lude98SH)
yeah it was a b16 manifold. i cut it off just before the injector tabs because im going to use my stock injector location. i'm not convinced that i could use the cbr injector location and benefit from it.
if they were engineered throttle bodies i could see that location being a gain, but not here.
the tubes are 50mm OD.
Old Jul 18, 2008 | 02:09 PM
2fastGSR's Avatar
King of the One Liners
I think using the stock injector placement is the right idea.
I actually drilled out the holes on my TWMs in order to move the injectors to the factory location and then welded the intended spot closed.
2 questions -
It may be my eyes deceiving me , but are the runners tapered at all? On the side shot they look like they get smaller closer to the flange.
Where the top ITB meet the bottom runners, Inside the rubber coupling, does the metal meet each other?
Basically what I am getting at is that if you have the top mounted and then it opens up in the coupling, if the metal does not meet each other directly then you may have a little turbulence.The air goes through the throttle plates, opens in the rubber cuppling and then hits the outside of the bottom runners. If they dont meet perfectly inside the coupling you may not have the smoothest airflow. . .
Just an idea to think about . . .
Old Jul 19, 2008 | 04:21 AM
lude98SH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paton5g &raquo;</TD></TR><TR><TD CLASS="quote">yeah it was a b16 manifold. i cut it off just before the injector tabs because im going to use my stock injector location. i'm not convinced that i could use the cbr injector location and benefit from it.
the tubes are 50mm OD.</TD></TR></TABLE>
I always though fuel would atomize better if the injector was moved up into the runner.
Old Jul 24, 2008 | 01:55 PM
balistik's Avatar
rofl crouch shot out of the blue no homo. *slaps forehead. in for results
Old Jul 24, 2008 | 03:18 PM
teg-96's Avatar
I want some^^^^^I'm talking bout the ITB!
Old Jul 26, 2008 | 09:29 AM
clem kevin's Avatar
hahahaha, good comedy
Old Jul 26, 2008 | 09:39 AM
logg_frogg's Avatar
In for results, looks liek a fun little project to me!!
Old Jul 26, 2008 | 01:20 PM
dom93hatch's Avatar
Keihin carbs = from a sportbike right? Which model?
Cool belt. What brand?
Old Jul 26, 2008 | 01:53 PM
Default Re: (dom93hatch)
In his first post he mentions 954 throttle bodies. so I would assume he means the Honda CBR 954 Fireblade....
Old Jul 27, 2008 | 06:05 AM
paton5g's Avatar
Default Re: (GhostAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GhostAccord &raquo;</TD></TR><TR><TD CLASS="quote">In his first post he mentions 954 throttle bodies. so I would assume he means the Honda CBR 954 Fireblade.... </TD></TR></TABLE>
yes the TB's are from a Honda CBR 954. The manifold was a factory b16 item, until I chopped it.
Old Jul 27, 2008 | 06:08 AM
paton5g's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dom93hatch &raquo;</TD></TR><TR><TD CLASS="quote">Keihin carbs = from a sportbike right? Which model?
Cool belt. What brand?</TD></TR></TABLE>
CBR 954 TB's
the belt is a Moosehead product. The picture of my waist area is the result of an inside joke between user Clem Kevin and I.
Old Jul 27, 2008 | 11:20 AM
jmoney45's Avatar
what velocity stacks are using and are you using a filter cuz i got the same setup and was just wondering
